System Specs
CPU - 2400G --> 5600 (from China)
Cooler - The stock AMD one to a Thermalright SE (£15 one)
GPU - 1060 6GB --> B580 (unopened)
RAM - 24GB, 2x8gb Corsair LPX 3000mhz in the main slots, 2x4gb Corsair LPX in the secondary slots
MOBO - Gigabyte Gaming AB-350m. I updated it to F53g and I think F52 for back up bios
PSU - EVGA 550 G3
So I have built 2 pcs before so I'm not a total newb to it. I will just state what I did. So I updated my bios to F53g which I believe supports the 5600. I ran a stress test to heat up my 2400g to make it easier to remove it and the stock cooler. I removed them and installed the 5600 and installed the new Thermalright SE cooler. My PC would then ask me for a bitlocker code which I didnt know at the time as it was a pirate copy. It then turned itself off. Then I rebooted and it turned itself off again at that part. So I booted into BIOS and it stayed on. I checked to see if I could adjust ram speeds and stuff and tried XMP. It was fine. I thought maybe it was turning itself off at Windows because I installed the cooler wrong so adjusted the Fan Curve to max. Then I left and same problem.
I took the CPU and cooler out and made sure I put them in right. Same problems. Then I thought I should try my old CPU with the new cooler. Now I'm getting no signal on my monitor. I removed my 1060 a few times when putting in the cooler so I'm thinking ive broken it. Okay I will try the integrated graphics still no signal. Then I try clearing the CMOS by shorting the two pins on my motherboard and now it just keeps restarting itself.
Is this recoverable? What should I do next? I feel kinda defeated at this point and thought I should just send the 5600 and B580 back but even then now I have no pc instead of the 2400G and 1060 I had before. Tried to upgrade and ended up worse than before
PSU - EVGA 550 G3
