Black screen for 2 seconds - Every so often
How old is your monitor?
If it has display port options you could try testing them.
I was looking at this Prevo DP14-2M on eBay for £7 but others seem to be selling it for £10+
OCUK don't appear to have any dearer ones at the minute
Pick up a standard cable - just to rule it out. Doesn't have to be premium.
New cable arrived today.
Got a £8 one from AliExpress in the end which is the same as some of the £14 ones on eBay, looks and feels good quality but doesn't have the push release style connectors.
Anyway... fitted it - but the problem remains.
Unlikely that 2 cables can both be faulty so I'll start investigating further tonight - not the way I was expecting to spend transfer deadline day! :cry:
Plan:
1st - Try it with just a power cable and monitor connected.
2nd - Disconnect the fans (not the CPU cooler fan) and try it.
3rd - Inspect all the wires from the PSU. (unlikely as i'm super careful but will check anyway)
4th - Try my spare Corsair PSU. (again unlikely but never say never)
5th - Motherboard removal.
Just out of curiosity...
If I remove the motherboard from the case and the issue still happens when I touch the metal on the motherboard backplate - where would I go from there? motherboard? monitor?
2 things I've bought this weekend that should have been easy jobs have turned overly complicated so I'm expecting this to go the same way :eek:
I don't know, I'm still not entirely convinced the problem doesn't lie in grounding somewhere between the monitor and the cable, since the problem doesn't exist with an adapter which suggests it is sorting it somehow (maybe because of how it terminates). I'm not an electrician, so eh, what do I know.
I'd say it doesn't really rule out anything, except a grounding issue with the case.
You may not be an electrician but your assumption appears to be... spot on!
Tonight when moving the PC into the kitchen to put on the table ready for investigating... I accidentally dropped the 4 way socket, thought nothing of it but when I switched it on to test it out after disconnecting the fans - I couldn't replicate the problem (with the first OCUK DP cable) despite messing around with it for 20 minutes.
Connected the fans back up - still no problem.
Tried the new DP cable from AliExpress - no problem either.
Connected the first OCUK DP cable again - problem back.
Switched the cable round so the plug that was in the PC is now in the monitor - no problem again. (the reason I thought to try this was because I noticed the cable didn't lock into the motherboard and I'm fairly certain it was locked in when I first tried it)
So it looks like the OCUK DP cable is faulty at one end.
Then I moved the PC back into the living room and... the problem returned!
But this time I was on the ball, the 4 way connector - no problem after I dropped it when moving it... I whipped the back off (obviously I switched it off and unplugged it first) and found that the screw for the earth wire was barely tightened.
Tightened the earth screw and as of the last hour - no more blank screens.
So it looks like the problem was a combination of a faulty cable at one end and my 4 way socket... when I plugged it directly into the mains to test it last week, I didn't think to plug the end from the monitor into the PC instead to see what happens.
Fault finding by dropping a 4 way adaptor sounds like something you'd see on a Lee Evans stand up DVD - so I'm going to keep playing around with the PC for a few days just to be sure the problem is definitely gone - fingers crossed :)
Eh, well, if it works it works :D
I hope you got it sorted!
The other day out of the blue I got a black screen again after unplugging my headphones and although I couldn't make it happen again it has been bugging me.
Tonight I decided that I would plug the old DP cable back in which constantly caused the black screen issue and then remove the motherboard from the case and also try it without the front panel usb/sound connected just to 100% rule out an earth issue.
However, since putting the old DP cable back in - I cannot replicate the black screen issue when touching my USB keyboard connector against any case screws, rivets or USB ports.
I haven't changed any cables or taken the PC apart or moved it since the other week when the issue was easy to replicate so can't see how the issue can be gone
I had a similar problem once, my PC that was in the living room at the time started going black for a couple of seconds, one time by luck I had the doors open and heard the fridge freezer compressor come on in the kitchen at the same time the screen went black.
Replacing the HDMI cable with a better one fixed it for me but it took a while to figure out what was going on and that it was combination of EMF from the motor and a cheap badly shielded HDMI cable to blame in my case.
Also you weren't wearing a big fluffy jumper or something were you?
Working at a college I once got quiet a jolt off a PC case, they PAT tested it and it was fine but said they have had problems with static in that side of the building before.
At a school they also had a problem with an audio amp in the hall causing the projector image to roll.
Earth loops, EMF and static can cause weird problems with video, a fibre optic hdmi / DP cable might be a work around if it comes back again.
Sorry for the late reply,
I wasn't wearing a jumper but I do often polish the surface of my desk so the duster could cause static, especially as sometimes I would have touched a usb cable a few mins after polishing the desk.
Currently the problem is happening when I plug my printer cable into the motherboard - or when I touch the printer cable against the DP socket on the monitor. (only happens with the printer cable now - no other USB device)
The monitor has an adaptor rather than an actual plug - I wonder if that is earthed?
My printer USB cable is fairly old - I'm going to try another,
I probably sound like a complete nutter :cry: but it gives me a constant niggle that I can't trust it and one day the screen will go blank and not come back on - almost like id expect from a cheap second hand system not a brand new one lol
Why would you do that lol.
I thought that if I did that and the monitor didn't go off - it would mean the problem would deffo be at the PC end lol
Stripped the PC down... motherboard on cardboard - problem remains.
Tried different USB and power cables on the printer, still happens.
Tonight I even found that if I touch my mouse USB connector against the old metal TV bracket on my wall which is a foot behind the monitor - the monitor goes blank for a second lol... only happens when using the DP connection with the monitor - fine with the HDMI cable connection
