Can I go wrong with the Viofo A229 Pro plus Hardwire Kit?
I have my dashcam powered from the OBD socket.
Can anyone recommend some sticky pads that will keep the dashcam on the windscreen? I moved my dashcam to another car so needed to replace. Bought some on eBay which looked good and its lasted a week before the dashcam is on the floor.
Just got myself a fitcamx clone for my Cupra Born, better sony camera and only £60I really wanted dashcam's that looked OEM - ended up going with fitcamx, and it's been awesome.
It took me five mins to fit the front one in my polestar, and an hour for the back one as I had to remove the trim - all connected to a block that was already behind my mirror, so no cables visible anywhere.
Gets a big recommendation for me if anyone is looking.
Sounds like a bargain....After my car was in getting a few things done, when I went to collect it yesterday, i noticed the advertisement for the MINI dash cams, there PRO version, front and rear, fully fitted £555!
Seems a good deal, might pounce on it soon!
