For some bizarre reason, the Daikin occasionally seems to ignore the DHW schedule. It was supposed to heat at midnight but didn't and is stuck at 28C tank temperature. This has happened on a couple of occasions since it was installed in April.
If you have a heating and hot water schedule start at the same time, it will ignore the hot water.
Time shift one by one minute and problem solved. It’s a known issue and bizarrely, it’s even covered in the manual in the troubleshooting section.
