There is discussion about a windowless side panel option but nothing is firm on that just yet.
it's been far too long.Just ordered one of these from OCUK for delivery tomorrow. Hopefully get it built Friday night. Was a decision between this, the Lancool 217 (do like wood but couldn't get in with the styling), the Fractal North XL (again like the aesthetic but several complaints online put me off) and the Vision Compact (decided it's too similar to my O11 mini I'm coming out of).
Looking forward to a more understated build as I've done the unicorn vomit builds for the last few. The 360 looks almost retro in design but with a modern cooling solution. Hopefully performs as well for me as it seems to be doing in all the review tests I've seen. Also just looking forward to building a PC againit's been far too long.
I did look at the Flux Pro actually, just really liked the look of this one in the end. Plus it's new and shiny and I'm like a magpie with stuff like this. The 360 does seem to be impressing the reviewers. Hopefully I feel the same.What about Antec Flux/Flux Pro/Flux SE?
Does anyone on this forum have one yet. I cancelled my order on the Flow and ordered the regular to give me the option of using the front fan bracket. I've seen zero reviews of the 180mm fans and wonder if there are dead silent at low rpm's like Noctua
Fractal North XL is my current top choice, but if Havn do a solid side panel for this I will definitely be tempted. Hate windows.That's what I found when looking for the reviews. GN is in the process to do a full video which I believe is due at some point. I've ordered anyway given the reviews from Oc3d and the tear down from Jayz2cents. Watched a few others and they all seemed positive. I agree it's similar to the 217 in performance from the days I've seen. I. Was originally looking at that case but then I saw this one. Actually it was the Fractal North XL that made me pause and then the 360 Flow popped up on an OCUK add on Facebook. And here we are
It's due today anyway as long as the DPD driver does his thing. Stripped out the O11 mini last night so it's all ready to go. Hopefully make a start after work and see how I get on. Have had to order a longer 8 pin cable as the one on my Sf1000 I (fortunately) noticed yesterday isn't going to be long enough. Why they don't give you a longer option in the box I don't know, even if it is small form factor. You get the ATX bracket but short cables.
What cooling did you run in the o11 mini? Will be interesting to hear from you on noise/ performance comparison as the o11 mini is a lot of cooling capacity in a small form factor.That's what I found when looking for the reviews. GN is in the process to do a full video which I believe is due at some point. I've ordered anyway given the reviews from Oc3d and the tear down from Jayz2cents. Watched a few others and they all seemed positive. I agree it's similar to the 217 in performance from the days I've seen. I. Was originally looking at that case but then I saw this one. Actually it was the Fractal North XL that made me pause and then the 360 Flow popped up on an OCUK add on Facebook. And here we are
I had a Lian Li Galahad 240 mk1 in the mini. It's what started this actually.... Somehow I've gone from the aio dying (known issue apparently and currently going back to Lian Li), deciding to buy a 360 aio that may or may not fit the mini to mana mathsing myself into a whole new case. The mini was running with 9 AL120 fans. I'll let you know the difference. The mini was quiet - not so much towards the end as the cooler was slowly dying and the temps were awful. I do like the look of the mini V2 and it's a great price point, but it's basically the same as what I had visually so I went for the HAVN.What cooling did you run in the o11 mini? Will be interesting to hear from you on noise/ performance comparison as the o11 mini is a lot of cooling capacity in a small form factor.
So - running the fans at 50% speed, case on desk - all I can hear is the AIO humm. 55% and upwards you start to hear them. 100% and they are obviously loud and I get a draught off the wall. All three fans are connected to my MB through the fan hub.What sort of speeds do you run the big 180mm before they are audible?
I can't hear any drone at idle. They start to make more noise than my AIO pump at around 55% speed.At idle do the 180mm fans make a low drone ? Are they Noctua quiet ?
