CPU upgrade
13 Feb 2010
Bournemouth
Hi all
I currently have an intel 6600k with an nvidia 1080ti
I am looking to upgrade my cpu and mobo in the next couple of months, and I’m just looking for recommendations.
Budget probably up to £300 max for the cpu.
I’ll be doing cpu and mobo, and probably switch to ddr5 first, and then graphics card can come at a later date.
I was considering an intel 12xxx or possibly a 13/14th gen, but then started to wonder if the core ultra’s are worth it over the previous gen?
I see a lot of people mention amd chips but their gaming chips are a bit out of my price range.
Thanks in advanced
Hi all
Thanks in advanced
Dont buy anything yet, keep saving what you can as Black Friday is only about 6 weeks away now.
The Core Ultra CPUs are good for productivity/mixed usage, but not so for gaming, you'd be better off with a lower-end AM5 CPU like 7500F. I'd wait for black friday discounts though, since they were heavily discounted awhile back.
12th gen is fine (e.g. 12600K), but I'd avoid 13th-14th gen K-CPUs, we still don't know if Intel has fixed the degradation issue with raptor lake.
If you get a non-K, like the 14400F, many of those still use the 12th gen die, so should be fine.
Thanks for your replies all
Yeah the main use for my pc will be gaming, with occasional browsing / media etc.. I don’t really do any productivity stuff, although occasionally I do tinker around in 3d design software but nothing fancy.
I was going to say there's duty to pay on that bit even still at £240 that's still a bargain. I was trying to hold out until AM6 but at that price I might even upgrade myself to AM5.
Check the comments you can skip the VAT.
Well it’s like the 5th or 6th, but it’s well up there.
Yeah I skipped over the 9900X3D etc as most people just go for the 8c/16t ones for gaming.
i think the 8 core ones would probably be above the 9900x3d in most gaming scenarios because if its only really using the ccd with the additional cache then its basically a 6 core x3d so im guessing outside of some fringe cases of a real niche game that uses more than 8 cores i think the 9900x3d would probably not be the best
i say this as a 5900x owner with 2 ccd with 6 cores on each
im pretty certain where if i need more than 6 cores i have the inter ccd latency penalties and whatnot
its probably not as big a thing as im making it sound but would guess the 9900x3d would be eitehr neck and neck or just behind hte 7800x3d
this is just a guess though i havnt double checked benchmarks and im also over generalising lol
so im probably wrong
bit confusing about the number of CCD thing I'm going to leave upgrades until 32 core single X3d CCD is available, for £200 :D
