It seems quite often, as they had that same discount when I needed new rears back in August.A bit of a silly question, but how often do Blackcircles run the 15% discount offers on Michelin tyres?
They’re currently offering a cracking price on a set of CrossClimate 3 Sports, but my current summers still have life in them. Would be nice to have all seasons for winter though.
Looking to get some 225 45 r17 tyres for my gen7 Celica. Where's the good offers at ?
Also are kumho ps72 any good?
Check out tyreshopper.co.uk too. They don't do Khumo but they do have some good prices on Goodyears. It's actually owned by Halfords so fitting is at Halfords, National Tyres, etc.Will check out black circles. Anyone got any discount codes?
Should I make them bigger?No one can see your imgur pics.
NoShould I make them bigger?![]()
Anyone willing to give me a sense check before i probably spend too much on two new tyres?
I'm needing 2 new rear tyres on a Fiesta Active, I'm looking at a pair of Pilot Sports or Crossclimate 3 from either Costco or BlackCircles respectively. Am I completely mad or should i be looking at something cheaper? if so any recommendations? I do around 200 miles commuting a week over a roads that are not the best in places during winter.
CC3 Sport or regular? can't really go wrong with the Goodyear Vector if you want to spend less money on an all season, but if you want something a bit closer to a performance tyre the only choice is the CC3 Sport really.
Not sure what your existing fronts are but I wouldn't mix all-season and regular summer tyres on the same vehicle though even on different axels - the response in different wet and cold temperature conditions will be different and can destabilise the car.
Personally wouldn't be putting Pilot sport or the like at the other end then - will be massively different grip levels.The ones on the front are are cheapish set of radar tyres that i had little other choice to fit due to circumstance. They are less than a year old so I'd prefer not to replace them, even if they are rubbish.
Are the tyres 225/50/17? That's a not so common size so there's less choice and higher prices. How common a tyre size is can effect the price more than size sometimes.Needing new tyres soon not looking to break the bank, only for a 2011 Honda Accord Tourer .
Whats the goto decent tryes (80-100) each for the family waggon.
