Should I update bios?
18 Apr 2013
After much faffing around today, (I'm not software savvy but can build a PC) I've finally managed to get my computer to boot in uefi and enabled tpm 2.0 on my MSI X570 tomahawk wifi. All I needed to do was change my OS drive to GPT but isn't as simple as just changing it in disk management but through command prompt. reason is to move to windows 11. I've managed to do this all on the original bios. (I thought I'd need to update it to do the above).
Before moving to windows 11 do you think I should update it or just leave it? I've never had any problems and the old adage, don't fix it if it ain't broke, seems to have been common in the past when updating the BIOS. Which makes me a bit insecure about doing this.
Bios updates will include newer Agesa versions and if you might be changing your CPU at a later date will need a newer bios that supports it.
I wouldn’t personally unless I was experiencing a problem that a BIOS update was likely to resolve. As you said, if it ain't broke…
So basically don't bother unless I'm upgrading the CPU. I have thought about an x3d upgrade at some point. Not sure how much longer the 5700x3d is going to be on sale for.
I wouldn't update unless there is a security vulnerability that needs to be addressed or it adds a feature that you need (e.g. new cpu support)
I have a board from the same family from MSI, and one of the latest BIOS release for mine fixed the sinkclose vulnerability, and an issue with the TPM and running some newer games, so more useful than just the usual microcode updates.
If it ain't broke, don't fix it! You only need to do it if you are having issues, or you are going to update your hardware.
BIOS updates fixes security holes, improves memory support, fixes any possible vcore overvoltage and can improve performance
They can also introduce those issues - which is how those issues would have been included in the first place.
Update your bios when and if the board is a new to market model (so more likely to have issues previously undiscovered) or you're trying to resolve a specific issue otherwise leave well enough alone.
It’s not as risky as it used to be in my view as many boards have recovery or dual bios support in case it goes wrong (check yours), so I usually update as issues that need a new BIOS (like security, upgrades etc.) are not ones you want to deal with years later. Better to do it when building/reinstalling assuming you have backups.
