Sounds catchy. My CUD (Compulsive Upgrade Disorder) is hereditary.Sounds like upgraditis
yup it is i wanna buy somethingSounds like upgraditis
I had the G603 for years and loved it. Same as the G703 but runs on 2 x AA batteries in parallel, so you can run it on one if you want a lighter mouse. Batteries lasted ages, too.Logitech G703 here, great mouse.
Bought it, tried for 5 minutes in WoW, sent it back. Hated it, like holding a brick but then I'm mainly an FPS gamer who likes smaller, lighter mice. If you've used something like a Deathadder it's similar to that just larger and heavier.anyone got any advice/opinion on the razer naga v2 pro?
Been using it since launch. Although yes, it is big and cumbersome. I unfortunately miss the side buttons too much on pretty much every game I play, so tend to stick with it.anyone got any advice/opinion on the razer naga v2 pro?
I agree, its very hard these days to walk in a shop and try a mouse before you buy it even curry's seem to have done away with their selection and focus on logitech nowBought it, tried for 5 minutes in WoW, sent it back. Hated it, like holding a brick but them I'm mainly an FPS gamer who likes smaller, lighter mice. If you've used something like a Deathadder it's similar to that just larger and heavier.
There's really no "right" answer to this question though, mice are a personal preference thing so you need to try a few out to see what works best. My favourite is the Lamzu Maya X.
