Gaming, what wireless mouse?
19 Mar 2011
As above, what mouse is considered a good mouse for gaming with both wire and wireless option?
currently i use the logitech g502 lightspeed, its alright does the job but recently been thinking if there is something better?
thanks
Upgraded from the standard old trusty wired g502 to the razer viper v3 pro and couldnt be happier, find it a great mouse and my kills on fps games have defo shot up.
Will it last as long as my going on 10 year old 502? im not sure, but it seems well built and feels excellent for my hands, very light also with amazing slidey feet.
I had the wired g502, liked it so much that I bought the lightspeed, came here to recommend that, so....
Buy another as a spare?
Or g502 X plus?
Or (regardless of what KB you currently have), buy a hot-swap mechanical keyboard, even if you have one already - easy way to keep yourself occupied and spend hundreds if not thousands of pounds for marginal benefit :P
anyone got any advice/opinion on the razer naga v2 pro?
Bought it, tried for 5 minutes in WoW, sent it back. Hated it, like holding a brick but then I'm mainly an FPS gamer who likes smaller, lighter mice. If you've used something like a Deathadder it's similar to that just larger and heavier.
There's really no "right" answer to this question though, mice are a personal preference thing so you need to try a few out to see what works best. My favourite is the Lamzu Maya X.
Been using it since launch. Although yes, it is big and cumbersome. I unfortunately miss the side buttons too much on pretty much every game I play, so tend to stick with it.
I just finally caved and upgraded from a 7 year old Logitech g903 which had developed some annoying issues. Bagged a Razer Deathadder V3 Pro for £95 and couldn't be happier, it's awesome.
Bought it, tried for 5 minutes in WoW, sent it back. Hated it, like holding a brick but them I'm mainly an FPS gamer who likes smaller, lighter mice. If you've used something like a Deathadder it's similar to that just larger and heavier.
I agree, its very hard these days to walk in a shop and try a mouse before you buy it even curry's seem to have done away with their selection and focus on logitech now :(
I got a g303 shroud.
Not because of link to the streamer, I'd actually never heard of him when I bought it, but due to the shape.
I like it anyway and plug PUBG at a reasonable level.
I used to like razor mice like 15 years ago but I think their quality has gone down the pan in recent years.
Just upgraded from G PRO wireless to the new G PRO X superlight c2
i have small hands so its even a better shape then the old G PRO.. and the new hybrid switches are very nice + its super light!
Depends on what you are looking for, mice are so varied and like anything else you wear or hold, how it feels matters more than specs. Only trying a whole bunch of them will give you an idea of what works best for you, nobody can tell you which is "best" as best does not exist as a general term.
I use the X2 CrazyLight, at 35 grams and medium size it is perfect for my grip
