Yep, it's an absolute mindfield!Yeah it's as you said
Way too many different models
Makes it confusing and a PITA to decide
Which to get
I would even consider looking at
Their air cooler instead
As its much easier to choose and to find
Reviews of
Assuming it fits in the pc case of course
The royal pretor Isn't all that far behind an aio
In performance
And doesn't have a pump which is always
A point of failure eventually
I can't remember which model/variant it was, as I've watched so many videos nowIt's not 60dba
I would just get the cheapest whichever fits your requirement (RGB/screen etc) tbh.
The only one I wouldn't get is the frozen notte which has an external pump mounted in line with the tubing - old design
but I'm 90% sure that it was 'Robeytech' that made the DBA claim under full load. I did think that cannot be right!
Frozen prism and aqua elite V3Which one do you have?
It isn't and is talking out of his arse. DBA is a logarithmic scaleRobeytech' that made the DBA claim under full load. I did think that cannot be right!
Difference in 30 to 60 DBA is 1000x!
My mate only bought it for a laugh mind
Cheapest 120mm I could find to cool my 7700How come you've got that Aqua Elite V3? It's supposed to be really loud and not very efficient and gets beaten by their air coolers?
Ah fair do's. It seems like the Warframe is going to be the only option then if the Notte has the in-line pump you say to avoid - it's more expensive that the Warframe even whilst on sale, despite it's lack of screen? But both have a 5 year warranty.Cheapest 120mm I could find to cool my 7700
It's actually pretty decent and slightly better in cooling capacity than an assassin king 120
As in go for the Aqua Elite V3 over the Frozen Warframe SE? Or did you mean, go for Thermalright over the price difference versus the Arctic?Personally I think their cooling is similar enough that I would go for the cheaper one
Yup, £25 difference, and will fit any case easily, versus having to hand pick and go all detective on which cases will fit the Arctic.Warframe if it's significantly cheaper than the arctic
I just randomly found this, you'll know why I find this amusing
They may cover refund/replacement of the AIO, but they explicitly state that they won't cover any other losses resulting from failure of the product.
(Note that they copied their warranty statement from Corsair's page and failed to replace one instance of "Corsair." lol)
THERMALRIGHT SHALL NOT BE LIABLE FOR ANY SPECIAL, INCIDENTAL, INDIRECT, OR CONSEQUENTIAL DAMAGES WHATSOEVER, INCLUDING BUT NOT LIMITED TO LOSS OF PROFITS, REVENUE, OR DATA (WHETHER DIRECT OR INDIRECT) OR COMMERCIAL LOSS FOR BREACH OF ANY EXPRESS OR IMPLIED WARRANTY ON YOUR PRODUCT EVEN IF CORSAIR HAS BEEN ADVISED PREVIOUSLY OF THE POSSIBILITY OF SUCH DAMAGES. Some local laws do not allow the exclusion or limitation of special, indirect, incidental or consequential damages, so this limitation or exclusion may not apply in your jurisdiction
Got a plot twist for you and @Mcnumpty2323 @Gray2233 @TetrasWarframe if it's significantly cheaper than the arctic
Yeah the case I'm using apparently supports it, I saw someone use it in a video, and it was the case+AIO combo that I wanted originally anywayAs long as the thicker 38mm radiator
Won't cause any problems
Then fair enough go for it
If you're top mounting it shouldn't be a problemYeah the case I'm using apparently supports it, I saw someone use it in a video, and it was the case+AIO combo that I wanted originally anyway
I'm rather excited now haha!
Front mounting it can be an issue sometimes
If you have a long gpu
Put one in my stepsons build in the front
Only to find the gpu was blocked by the middle fan
Of the artic
Had to pick up a slim 15mm artic fan which meant
The gpu fitted but it was a very tight fit
Yeah sometimes you just have to go with
What you want
And to be fair the artic isn't ridiculously priced
Compared to some of the corsairs etc
it's a swear word now after my PSU RMA debacle
