Hello,
I built a gaming PC 2-3 months ago & everything was a dream. Or at least I thought until I ran into an issue last night & after doing some research I’ve realised I messed up badly.
I installed my Mobo directly into the metal frame of my PC case. I didn’t realise you’re not supposed to do that. Anyway, I’ve been using my PC almost daily since I built it, but last night it did some things it’s never done before.
It started up fine, I was launching a game, and then boom. The power cut out. Thinking nothing of it, I turned it back on again. At this point I got a black screen with a message saying “Your PC didn’t restart properly, we’ll restart it for you now” or something along those lines. So I waited, but nothing seemed to be happening. After several minutes, I turned it off.
When I turned it back on again, a static red & orange light appeared on my motherboard. I had this issue when I first put my PC together, but it was because I hadn’t correctly seated the RAM. This time, I knew that couldn’t be the issue.
Then, my fans started going into overdrive, it sounded like a jet was about to take off in my office. At this point I was stressed, so I took apart my entire PC and built it back together. I checked every single part & wire in my PC, no visible damage apart from a couple of very small scratches on the baseplate of my CPU cooler. How they got there, I don’t know.
At this point, I was trying to find an explanation to my problem online, and I came across a thread in this forum that mentioned incorrect Mobo installation I.e not using the standoffs during installation which can lead to a short circuit.
I figured this could be the root of the problem.
I’m just wondering if anyone can tell me, is my mobo now FUBAR?
After putting it back together & turning it on, my PC seems to be working again, at least for now. I launched a game just to check it would launch & run normally when it opened which it did. But now I’m conscious that the issue may not be fully solved & I don’t want to risk doing further damage if I can prevent it so I haven’t used it since. But, for some reason the MnK would go from working fine to just cutting out, and I’d then have to restart the PC for them to work again. Not sure why.
I’m using an Asrock B850 Pro-A M WiFi motherboard, with an AMD Ryzen 7 9700x CPU. I made a post on Reddit about my issue and someone replied with a bunch of links to people having issues with the same motherboard, saying it died within a few months of purchase & that Asrock are generally pretty unreliable.
Obviously I realise it’s completely my fault that I didn’t install the mobo correctly. Do I need to replace it? Will it survive now it’s installed correctly or is the damage already done?
Thank you.
Thank you.
