Hi
I am looking for a new pre built system like one of the towers on your homepage: OcUK Gaming Karambit - Intel Core i5 14600KF, GeForce RTX 5060 Ti Gaming PC and it will be used for gaming.
I want to upgrade some parts of it, like: the case, the memory, the cooler, and the solid state drive, can you tell me if this is a good combination.
Upgrade the Lian Li Lancool 205M Mesh Micro-ATX PC Case - Black to the Phanteks Enthoo Evolv Micro-ATX Glass Case - Black (+ £55.04)
I am happy with the cpu: Intel Core i5-14600KF (Raptor Lake-S) Socket LGA1700 Processor - Retail (No price increase)
Upgrade the Kingston FURY Beast 16GB (2x8GB) DDR5 PC5-44800C40 5600MHz Dual Channel Kit to Kingston FURY Beast 32GB (2x16GB) DDR5 PC5-44800C40 5600MHz Dual Channel Kit (+£60.00)
Upgrade the MSI MAG CORELIQUID A13 240 BLACK ARGB Performance All In One CPU Cooler - 240mm to the Cooler Master MasterLiquid 240 Core II ARGB All In One CPU Cooler - 240mm (+£7.00)
I am happy with the graphics card Zotac GeForce RTX 5060 Ti Twin Edge 8GB GDDR7 PCI-Express Graphics Card (No price increase) but it does say to pre order?
Upgrade the WD Black SN7100 500GB SSD NVME M.2 2280 PCIe 4.0 Solid State Drive to the Crucial T500 1TB NVMe PCIe Gen4 M.2 Solid State Drive (+£13.00)
Add an extra solid stare drive: Crucial P310 1TB M.2 2280 PCI-e 4.0 NVMe Solid State Drive (+£61.99)
I am happy with the operating system, Windows 11 Home Advanced (No price increase)
I have a keyboard and mouse, speakers and a monitor.
The monitor is around 6 or 7 years old and uses either VGA or DVI to connect to my current tower (will need to turn the pc off to check it), but will it connect alright to the new tower or is it old fashioned and will need a newer type of connection? (I am waiting until black friday to see if there are any good deals on monitors).
I am looking for a second solid state drive to use one for the operating system and the other one for storage, all my files and downloaded games, etc. Or will it be just as good having the operating system and file storage on one solid state drive?
I can see two USB ports on the front of the tower, are there more on the back of the case?
My wireless keyboard and mouse will need one usb port, my headphones will need another USB port, i have external hard drives that i connect on and off using usb, so an extra one or two USB ports on the back of the case to take the keyboard dongle would be great to free up at least one of the two ports on the front for my external hard disks.
What about WI-FI, i see no mention of a wi-fi card in the build and i will need wi-fi?
Are the two round ports on the front of the case for wired speakers, my Logitech speakers are currently plugged into the back of my tower, the speakers are also 6 or 7 years old?
Approximately how long will it take and what will be the process when i order the tower?
Are delivery days Monday to Friday, just seeing if i need to take time off work for the delivery?
Edit - I had the price worked out at £1397.02 with the upgrades on on the homepage?
Thanks for your help,
Andrew.
Andrew.
