My all singing all dancing Samsung broke out of warranty. Just replaced it with the cheapest heat pump 10kg dryer and it does an even better job at drying, the Samsung always switched off too early in winter.I know this is a bit of thread revival but I have been informed we need to look at getting a tumble dryer again, so looking at heatpump ones, normally I go with Beko for my white goods as always had good experience with their stuff, so looking at their offerings, but anyone else worth looking at in the £400-£800 range? I know bit of a broad budget but want a good set of options.
Not fussed about it being smart connected, but would want a reverse function so bedding does not come out looking like a pretzel.
Cheers
Sharp KD-NHH0S7GW21 10Kg Heat Pump Tumble Dryer
Sharp KD-NHH0S7GW21 10Kg Heat Pump Tumble Dryer - White - A++ Rated
This KD-NHH0S7GW21 Sharp heat pump tumble dryer has a 10kg drum capacity, a Bubble Drum, Two Way Tumbling and 8 Sensor Drying tech.
