9700XT constantly crashing
I have an AMD 5800x (so exactly the same CPU) with a mild over clock, 7900xt and an 850w power supply and have absolutely no issues, you do not need a 1000w power supply.......
Edit: oh, and it's roughly a 15 year old Corsair HX 850.
remove xmp/reset bios to stock
RAM doesn't often go from good to bad, but it can happen. Sometimes it's not even RAM but memory controller or motherboard having trouble. You can try them on stock non-XMP settings, see how they behave.
I haven't changed the bios yet i tried turning off XMP no joy. I install only one ram module and it passed the test time to test the others...
Corsair are pretty good with RMA's so they'll probably send you out a new set if you contact them/start the process.
AM4 can be a little finicky with more than two dimms however, so that might be the problem.
You have 4 sticks, generally recommended to run with 2 sticks. The IMC can sometimes be flaky even if all of the sticks are fine.
But I have been running 4 dimms for years, only noticed issues since around the time I upgraded my GPU.
A more powerful GPU means there's potentially more strain on the CPU, memory controllers can also degrade over time.
Fingers crossed you just need to replace a bad stick of RAM, but switching to 2x16gb might be necessary.
  • Like
Reactions: G J
I see, well I tested two Ram sticks and the pc shutdown, no blue screen? I repalced that RAM stick and the test passed. So it might be that one ram stick, I need to test one more but I think thats enough for today will report back tomorrow!
Thank you all btw, you have been very helpful. I think i will give my GPU a little undervolt while im at it...
I wouldn't change anything regarding undervolting, till you're 100% sure it's stable in new configuration - don't introduce new variable yet, or you'll start chasing your own tail with crashes.
Might be a bit time consuming but I’d be running Memtest86 from a bootable USB drive with one memory stick at a time for a couple of hours.
You might find that the faulty stick will error very quickly.
I did try this but it was taking ages Iff i put all 4 sticks in will it tell me which one has failed?
In short words yes, sometimes with a bit of math though. However, then you would have to test it solo too, to be sure. As error might not be related to this stick itself but to for example 4 sticks being put in at once generating random errors. I had this issue on 5800x3d, till I underclocked them a bit and then I swapped for another brand which solved the problem completely.
Average gaming loads of 350w with peaks of 382, a good 650w PSU should technically run a 9070XT but transients could be a problem
Been having a play around with the Sapphire Pure 9070XT which came with the pre-built unit I got a couple of weeks ago.
Overclocked it to 2850MHz memory (fast timing) and 200MHz max offset on the GPU. Ran the Adrenaline stress test for 10 minutes and HWinfo 64 reports max gpu power of 588W, min 25W and average of 344W.
That's a fair old spike on the gpu if the cpu is also under significant load at the same time. Top grade 650W PSUs would probably cope but if its a regular thing its unlikely to do them much good long term. 850W seems a sensible starting point for these GPUs.
YMMV of course.
YMMV of course.
I would still put money on it being the PSU
Its one of the reasons I opted for a pre-build/build to order. I know bugger all about consumer PSUs these days - rack mount stuff I know what to buy because it generally does what it says on the tin, or at least doesn't have wildly optimistic specs.
We digress :)
Didn’t the OP find they had a faulty RAM stick and will report back? If this was a silver or lower rated PSU I would understand but the Seasonic Focus GX 650 is a good PSU.
One way to test the PSU is to set a negative power limit in the GPU. Setting this as low as it will go will significantly reduce power draw (and spikes) of the GPU.
I have been using a 9070XT pulse with a 7800X3D, 32GB of 6000 DDR5, 2x NVMe drives and in an older EVGA gold 650w PSU. Absolutely zero issues with this setup. It even accepts a max power overclock but is generally run undervolted with a -15% power limit to keep the GPU at about 280w and stock performance.
A decent 650w PSU will run a 9070 XT with a top end AMD CPU with no issues.
