Fans suggestion's
1 Mar 2024
Leeds
Im building an all white pc for a friends son for Xmas he's happy to spend what's needed but not just for the sake of spending.
his son like my D30's but i was wanting to know if anyone as any suggestion's on fans that don't cost £170 for 7.
the only fans im 100% against in the M25's there just loud and make a lot of noise at low RPM's, he wants the fans to look premium
My basket at OcUK:
Total: £170.96 (includes delivery: £0.00)​
I'll always stick with the D30 when you can fit them being 30mm, due to the noise they make when set up correctly they also have one of the best cable systems for RGB fans imo and don't require you being tied into an ecosystem like most other providers.
There's a reason they don't seem to stay in stock often and if you look at most places prebuilds they favour the D30 on the mid / high end builds
£14 (incl. VAT)
£10 (incl. VAT)
£13 (incl. VAT)
£10 (incl. VAT)
i love the fans, got them in 3 systems. just my buddy said he's happy to pay the £170 but said is there any good alternatives.
we looked at the Lian Li UNI but OMG why is there so many different types and each one needs a different controller.
my head started to hurt just trying to finds 3x120mm 3x140mm and hopefully a 140mm reverse, just when you think your all good you notice one is a tl not an sl. or in and an infinity or what ever.
Li UNI really need to sort out the fan line up
Jonsbo do some very nice fans. The white Jonsbo ZK-120W (ZK-120WR for reverse fans) are excellent and not bad value at £38 for a pack of three. No software required as they just use the motherboards software or Windows 11 dynamic lighting plus no wires between fans as they connect in a similar way to Lian Li's Uni fans. I have some slightly different ones (BR-120R) in the bottom of my case and they look great.
really good job i didnt buy the d30's, put the system together today and there is not a millimetre of space in the fans
Can never find them in stock in the UK, seems to be a import from US.
Phanteks M25's have 120 and 140mm options, not badly priced either:
My basket at OcUK:
Total: £59.98 (includes delivery: £7.99)
Scratch that, just noticed you're dead set against them. :cry:
the stock fans look ok, the just sound like ass, if im going to end up with the same/same i will just advice he keeps the stock ones
there is 2 GPU power cables in the post haha
