either dropping from helicopters, abusing drone/sledgehammer bug or creative use of assault laddersAre the people on bridges and roofs cheaters? had a few last night
The thing is though, I had done all what I said about 10 seconds before and had just killed 3 people.They need to increase the inactivity time.I can just go to the toilet quick and I’m back on the home screen when I come back down
I agree, but the thing is I hadn't been afk, while on the pipe I had been moving looking around all the time and I had just run about 20 feet. It's not not like I had been sniping, I play as support with a LMG.+1 on longer afk timer needed, went to the door when pizza arrived, prolly only about 1 min, and got back to the menu.
Agreed, I feel like they're overwhelming as well as you have to have 360 vision due to all the angles.The more I play the more annoyed I get with the tiny maps, I want the old school giant maps back. Not tried BR yet but it's not a game mode that appeals to me.
The deploy beacon is temporarily disabled in some small modes:either dropping from helicopters, abusing drone/sledgehammer bug or creative use of assault ladders
Yesterday got hit with a few bugs
Deploy beacon is bugged in small modes like TDM or Domination. Previously it allowed to respawn while downed meter was running, instantly. Probably a bug.
Still allows that, but then after the original downed time runs out my screen goes black. Fine, redeploy, all looks fine but then screen goes black again after some seconds. Need to leave the game.
Another time same thing happened and I got stuck in class customisation selection page with no way of leaving it, including Esc to menu didn't work. Only Alt-F4
Some reported they can't use Deploy beacon in small modes at all.
Probably partially finished bug fix causing weird stuff
The new 4 on 4 mode end of round message "We lost, all squads eliminated" etc. FFS there was only one squad
In same mode if you joined mid-match, there is no scoreboard
Farming suppression with LMG is a pain. Suppression apparently only triggers if you are shooting and missing an enemy that lost some health. Because all suppression does is keep them in combat state and prevent health regen.
yeh been noticing something off with the graphics today.Anyone had a bug/issue where the games graphics seem to downgrade and become fuzzy/lower res mid round. Almost as if an extreme version of FSR is getting applied that downgrades the image quality. It then magically sorts itself out after a few mins and goes back to looking normal.
Hit reg still feels off at times for me hopefully they can sort it
Same with every battlefield release though. BF6 is such a good game I'm sure they will fix it they usually do just hope it's not too late this timeYep!
One round and I was done...
They just wont fix it![]()
