Intel has a Pretty Big Problem..
Where is the contradiction? as I said I don't have access to Intel's return data but I have enough insight into some retailer's returns data to have an idea of the scale of the problem - it would certainly show up there if it was remotely close to the 20, 50, 100% failure rates some claim.
I also pointed out that the claims in the media made by certain parties of ridiculously high failure rates weren't able to be verified by the likes of GN while we have claims by a substantial source who have a verifiable industry presence which are likely more accurate.
No idea what you are referring to with the "You even double down and claimed to data that shown AMD had an issue." comment.
There are no facts I'm arguing against - I've even repeatedly linked to facts which don't support the claims you keep referring to.
You either have the data to backup the argument or you don’t. Which is it?
Show the data or stopping trying to debunk established facts that Intels 14/14 gen failures are ridiculous and the platform is crap.
I've shown plenty of data in this and previous threads which is sufficient to disprove your position, not my problem if you won't take it in.
You keep saying that, but the facts remain… Are you going to backup your claims and provide the evidence you claim to have or not? I’m being to think you might actually have some, but it also proves the severity of the 13/14th gen issues.
The RAD Games information alone shows the real scale of the issue in comparison to your claims, the rest is just denial on your part.
We can keep going around this but it doesn't change that you can't provide a single verified piece of information to support your claims and I have provided plenty of substantial information that shows otherwise.
Talk about projection and cope.
Show the data you claimed bebunks the issue.
Someone enjoys their 13600k, and jigger urinates his pants, foaming at the mouth.
Classic OcUK CPU section.
It’s not foaming here, Rroff wanted to go another magical mystery tour. I told a user not to pat 13600k too hard or it might fail because probability is harsh mistress. The poor chap then went to tell how great his chip is…
We've all seen the videos, no one has ever been able to substantiate level1tech's sources for mass failures and one of them was even claiming to be seeing these issues on 13th gen models which are rebadged 12th gen parts using a different architecture which can't be affected by either of the main causes of degradation. Alderon Games aren't the only ones doing that kind of Unreal Engine dev on 13th and 14th gen CPUs, in fact there are dozens and dozens of studios just like that doing similar stuff, it isn't like they'd keep quiet if they were seeing anything like 20% failures let alone the 50-100% claimed failures. One of level1tech's sources didn't have the data to distinguish between whether lots of error reports were being generated by lots of unique players or whether a smaller number of players were generating lots of reports each (the second being the more likely scenario given other factors).
As I've mentioned before we've information from RAD Games Tools who were one of the first to discover the issue due to their products being widely used in games and susceptible to tripping the main compression/decompression issue and they are still saying it only affects a small number of CPUs mostly i9s. Related to that we can look at the nVidia forums where one of the early symptoms was out of memory errors from the driver and again there are a small number of reports but nothing consistent with massive failure rates.
We can look at the Asus forums which was one of the other early places these problems started to be noticed and again it is only a small number of reports, mostly i9s and mostly people who are rinsing these CPUs with heavy overclocking. (For example the pinned thread here has few actual reports and is mostly discussion of the BIOS updates and news https://rog-forum.asus.com/t5/intel...ility-reports-on-intel-core-13th/td-p/1030853 ).
We can look at these forums as well as other tech forums, for supposedly "ridiculous" numbers of failures there are like 2 other posters who've reported failures consistent with these degradation issues and there are plenty of people posting here who own 13th and 14th gen parts - not consistent with massive failure rates - these forums would be one of the first places where it would be appearing as can be seen with the 9800X3D issues if it was that prevalent.
There are retailers like Mindfactory who publish return rates for their CPUs - for the 13th and 14th gen, despite a spike of people reactively returning their CPUs when the news broke, the return rates average below 2% with only the i9s seeing slightly elevated failure rates - which doesn't support these claimed massive failures.
The Reddit megathread has hardly any documented cases of 13th and 14th gen failures consistent with these degradation issues, in comparison the 9800X3D megathread has more than 4x the number of documented failures despite being a more recent issue and no one is calling that massive failures. (EDIT: There are 1-2 reports in recent days, since I last looked at it, which are maybe this issue on the Intel one but you have to go back months for the last reports which are definitely this degradation issue).
Despite the claims by one of the devs, who later rowed back on the claims a bit probably due to realising a high number of the errors were from the same small number of users, we can see on Bugzilla the reports of failures on 13th and 14th gen CPUs for Mozilla products - the number of reports consistent with 13th/14th gen CPU degradation average about 15 a month out of 10s of millions of users and many of those are the same users generating multiple/ongoing reports.
Where are all these mass failing CPUs? because no source which is possible to substantiate are holding up to there being anything more than a small percentage of failing CPUs at this time.
There is zero actual evidence of failure rates above low single digits.
There are regular failures reported right here on OcUK One at the bottom of this very page. If you have the data show it. Otherwise you’re just peeing into the wind. Intel has a pretty big problem and that problem remains.
There are no regular reports here, I never said said there are none at all, never mind anything even remotely close to supporting your claims of ridiculous levels of failures.
Even considering AMD have been outselling Intel at about 9-1 post 12th gen there are still regular post claiming issues. You may just be subconsciously filtering…
Where are all these posts that support a ridiculous level of failures?
You'll find many more posts of people having 9800X3Ds die and no one is claiming they are mass dying.
One on this page..
The failures are massive. Intel was confident of having enough chips to cover the RMAs and run out in less than 9 months with mitigation in place…
They ran out because people mass reacted to the news and started returning their CPUs whether they were showing issues or not - the return rates were fairly low before the news broke and quickly returned low after with return rates averaging approx 3% across the range despite that. You are really reaching and still finding nothing to support your claims.
Go on where are the rest of these 100s of posts supporting ridiculous levels of failures?
lol, more projection and cope. An internet search returns thousands of results. Same for YouTube and Reddit. The information is out there.
But speaking of failure, show your data… If you can’t understand what you’re looking at or how to present the data, I’ll even SSH in for you.
So you have nothing then, I'll continue this discussion when you bring something of substance which backs up your claims.
