Question about Ultrawide monitors...
5 Nov 2024
Oxfordshire
Are there variants that have both G-Sync and Freesync support?
I want the PBP feature which i know ultrawides are designed for that, however my question is, if a model supports both syncs, can the screen detect those on individual inputs?.
Basically could i have G-Sync one side and Freesync the other or are they not designed like that?, so instead it will just recognise both systems connected, but both sync options would be disabled?
There are monitors that support both NVIDIA G-Sync (or “G-Sync Compatible”) and AMD FreeSync (or Adaptive-Sync) but if I'm understanding you correctly, there is no guarantee that you can use them independently per input (one input using G-Sync while the other uses FreeSync) and have both VRR systems active simultaneously in a multi-input or PBP/PiP (Picture-by-Picture / Picture-in-Picture) mode.
I would be very surprised if you could use G-Sync and FreeSync simultaneously on the same monitor.
Ah ok good to know and ok then thats fair enough.
I wasn't sure if any of the new fancy spec gaming ones did it or if it just simply not a thing altogether. Its not a selling point. it would be convenient, but i wouldnt need to have both systems connected like that, i was just curious if there was the technology for it.
