My gpu Ambiguities
Query with the place you bought it from. If OCUK you can raise a ticket or create a post in the customer service forum.
Its not something I'd personally waste my time querying though tbh. Looks like it could have happened during shipping. If the card is not damaged then it did its job.
I ordered a custom gaming pc and when I received that, I noticed my gpu box foam is damaged!?
Now I really concerned and upset that is my new gpu and system second-hand or refresh!?
It is fine, don't worry about it. I'm surprised they even bothered to send you the box :o
I did that and on 1080 extreme settings, I got 13560...
Now I am not sure is the score proper for this model or not!?
Guru3D include 3D Mark scores in their reviews, but I can't check for you, because I don't know which benchmark/version you ran, or what the card is.
as I said, I did not get that gpu and other components directly and right away...
I mean I ordered a custom gaming system from a local computer store and actually they assembled the components that I have chosen...
actually I received the whole system together...
You've got it, it works, what's the problem? Are things done differently in Iran?
So long as everything works you’ll be fine, I’m assuming the shop where you bought it has some kind of warranty cover should any issues arise?
Looks to me like the foam has done it's job protecting the card during transport.
As long as the card/system is perfectly clean, has that addictive and comforting 'new electronics' smell, you should be all good.
