UPS plane crash
7 dead now, 3 on the plane and 4 on the ground. Poor guys didn't even have a chance.:(
Jeeeeez, on that first one you can clearly see the left engine entirely missing. I saw elsewhere that the centre engine was ingesting that fire you can see around the left wing, making the centre engine surge.... so they're down to one engine just a few feet off the ground. Christ.
Well, that makes it 11 out of 200 built lost in accident. I’d say that as far as modern commercial aircraft go, 5.5% is a pretty hefty loss rate.
It would be better to work it out as a percentage of the number of flights completed over the 40 year period. If 200 went up on day one and then 11 failed to return then yes that’s a pretty hefty loss rate unless it’s 1940 and then it’s pretty good!
That is over a small sample size however. 737 is around 2% I think. DC10 which this is based off was around 3% and operated during a time where safety wasn't as good as what it is now and also small numbers of around 400 compared to 11000 with the 737.
Something serious has been neglected for an engine to fall off during take off. That isn't a fault of the plane really. The last accident with this craft that resulted in fatalities was 16 years ago.
It would be interesting to see when incidents happened over time on a graph, say.
Aviation is meant to be one of the best industries for safety improvements. But I guess it would be difficult to
infer anything from a simple line graph.
It doesn't change anything for those who are lost. I hope they find out what happened.
