Hi guys, I decided to treat myself to a new case, the lovely Lian Li 011D XL evo and covering options I got both the vertical and upright GPU mounts but I can`t make my mind up which one to choose.
First option is the vertical mount with the pump and reservoir mounted to the vertical fans, although the pipe routing is a bit more difficult I slightly prefer this.
Second option is the upright mount which I like, the pipe routing is easier and I like the location of the GPU but it hides the fans and could probably get a bit of noise from the fans blowing on the back of the GPU. I`m also not sure on the pump and Reservoir location as it looks a little odd looked worse elsewhere.
What do you think?
I haven`t placed the top radiator and fans yet and I still have some tweaks to do but I`m torn between the two.
What do you think?
