Palletised delivery I think, it is what it is.I ordered an H2S last night. Was gobsmacked at £80 delivery charge but what can you do? Hoping it comes tomorrow as I've taken the day off work.
It’s probably too big for the likes of DPD and they’d smash it to pieces.
What's your print surface, pei sheet or something else?suddenly getting prints pulling up at the corners. really don't want to go back to the old pritt stick. whats everyone's go-to hair spray?
I’ve had much less issues on my Bambu A1 since moving it further from the doorI had similar on my Ender 3, was a through draft issue, put stuff next to the printer to block the flow of cold air and it solved it for the most part...
What cardboard spools do you use? I’ve always put them in the AMS without any covers and not had any issues and no sign of dust/fibres like I’ve seen reported.The H2S is an impressive machine that’s a lot quieter than my X1C.
The only negative I have, other than the bloody weight (my poor back), is with the AMS 2 Pro. Bambu Lab could have accepted people use filaments other than theirs and made the new AMS able to take cardboard spools, with the printed adapters, with the lid fully closed.
I've got some Eryone cardboard spools and recently(ish) they've increased the diameter. The bigger ones, with the printed adapters are just too big where I'm currently printing with some Eryone PETG, I bought in 2024, that with the adapters just fits.
I'm not going to buy any filament with cardboard spools from now on, save for any specialty filaments that use them, and stick to Sunlu and Bambu Labs reusable spools. Plus any other brands that use reusable, I just wish they'd all get together and come up with a bloody spool standard.
I printed this recently that works a treat with a drill and re spools in minutes.
Pastamatic Filament Spool Winder for Bambu X1C/P1P AMS (level winder with self reversing leadscrew) Remixed by GekoPrime MakerWorld: Download Free 3D Models
I tried another spool winder but found it finicky and delicate.I designed this winder from scratch to be simple and robust, using the same self reversing leadscrew mechanism found on industrial cable windersWhy pick this model:Prints on a single build plateDoesn't require heat set inserts or...makerworld.com
I think I am going to have to print off that rewinder because I have several cardboard spools and hate them. I vacuum seal my filaments after use and it destroys the cardboard spools plus I have a couple of empty spools doing nothing now.
