Building a PC
17 Feb 2023
England
Hey,
I’m looking to buy PC parts to build one for a budget of around £700 more or less
I play FPS shooter games, that require high frames. I already have a 240Hz monitor so I would like to be able to reach in terms of FPS on the majority of my games. I am looking to buy GPU and maybe CPU second hand if that would mean that I can get more performance for cheaper.
Please may I get a full list of recommended PC parts to form a full pc, case included as well as RAM, PSU etc
£700 is a tight budget for a gaming PC.
I assume you're aware that this is not going to achieve top-end FPS? Depending on the games you play, and the resolution/detail settings, 240 fps is very likely an unobtainable goal.
You can go Cheap, or you can go high FPS. Sure you'll get high frames out of CS:GO2 with relatively modest equipment, but if you want high FPS, 180+ on the likes of COD, Fortnite etc, £700 isn't going to cut it.
Even with just a 7600X, B650 board and 9060XT 16GB you're at £600 already and if you want high FPS that's where you need to be at.
My basket at OcUK:
Total: £607.97 (includes delivery: £7.99)​
Hey,
Ram is absurd price now, and I'd recommend 32GB. Last time I looked 32GB is closer to 200GB or so. Add in a GPU cheapest but good is Intel B580 that's about £250, that's most of your budget gone already, and you still need case, PSU, motherboard, CPU, nvme drives, unless you can reuse existing bits to make the new system up
Sorry, critical error on my behalf.
Turns out my monitor is 120Hz.
Would that help?
for £700 and using new components, 1440p 120hz is a tall order for £700 and tbh, even 1080p 120hz is as well
you'd probably be needing to turn settings down.
what kind of "FPS shooter" games are you intending to play? if it's anything new-ish AAA titles like COD/BF then expectations will need to be managed
True, but will that get him 120FPS in 'competitive shooters'?
Depends on which ones and at what settings. A quick Google indicates that the B580 should get 140 fps at 1080p extreme settings in CoD: Warzone, for instance, and 120 fps in BO6 on 1080p with balanced settings.
I’m not particularly fussed about playing the triple A titles that have extreme graphics. I’m more for simpler competitive shooters, e.g fortnite or csgo or even roblox games if that helps.
realistically you'd be looking in the ballpark of something like this:
My basket at OcUK:
Total: £744.90 (includes delivery: £0.00)​
you could go AM4 (eg Ryzen 5600) to save £50-100ish, but fortnite/CS usually relies more on single-threaded performance, so going AM5 with the Ryzen 7600 is the better choice here
you could also go with a cheaper case and save £15ish, but these cases don't usually have good airflow
£219 (incl. VAT)
£161 (incl. VAT)
£140 (incl. VAT)
£129 (incl. VAT)
£230 (incl. VAT)
£200 (incl. VAT)
£78 (incl. VAT)
£65 (incl. VAT)
£55 (incl. VAT)
£50 (incl. VAT)
£46 (incl. VAT)
£40 (incl. VAT)
I wouldn't normally suggest you look at 8GB cards (and if there's any chance of upping the budget, DO IT!), but in the circumstances (where you're looking for high FPS primarily), I'd have a watch of these videos with the 9060 XT 8GB.
Though, despite it coming out well here, glass cannon comes to mind. It is a very situational thing and could easily bite you in the bum later (note these results are also subject to PCI-E 5.0 on the motherboard).
Yeah, I think I would prefer having an Nvidia or AMD gpu to the intel one. Could someone provide an effective alternative along with the rest of the components that need changing from the list if needed:
My basket at OcUK:
£219 (incl. VAT)
£161 (incl. VAT)
£140 (incl. VAT)
£129 (incl. VAT)
£230 (incl. VAT)
£200 (incl. VAT)
£78 (incl. VAT)
£65 (incl. VAT)
£55 (incl. VAT)
£50 (incl. VAT)
£46 (incl. VAT)
£40 (incl. VAT)
