4G/5G is good enough decent 35mbps down indoor, so I have decent backup. Outside even better. And I know stuff happen, it's how they respond that's important. And "touch wood" I have not had any technical issues in 7 years and I count my self lucky. I want to give these guys a try though but might wait a little longer I am in no rush.My advice where people want reliability/availability is to have a backup, not to try and find a provider that is less likely to have a fibre break or fault than another one. If you have decent 4G/5G options in your area then your backup plan can be tethering off your phone for the maybe 1-2 days that your fibre is down for, admittedly if you have no viable mobile options this becomes trickier.
It seems you are correct. I had not considered that there would be no 2.5Gbps output. (that seems like a pretty serious oversight but I had not considered that I would ever have a connection this fast when I purchased it in 2019)You need to contact them and ask them to reprovision the ONT, seems they are getting stuck on the old speed
profiles.
Edit Checking the speed of the ports on a ax11000 it looks to have the WANport as 2.5Gbps with only 1Gbps ports for the lan. Have you tried the supplied router ? It is poor but can conform of the ONT is working at 2.5Gbps
OK got it, thanksThat speed profile suggests it's an Openreach area, their products are (currently) not symmetric.
You are in a open reach area it seems upload is max 115 on residential services it can go higher on business services.Good morning all
So we are currently with YF and moving to a 1950s house in the new year, YF aren't in that road as yet, but punching the postcode and property address in shows FTTP providers but only at 1gb down and 115meg up? Or copper via VM
I work in tech and have a Unifi network so I'm really looking for a reliable provider, a good friend of mine lives in the same road and has EE, just trying to understand why they have FTTP but the upload is less?
Thanks
Thanks! I did talk to a friend who lives at the same there’s of the street and he thinks maybe they didn’t go all the way down that road, there are probably 30-36 houses in the lane, maybe I’ll call EE and ask themYou are in an open reach area it seems upload is max 115 on residential services it can go higher on business services.
