- 25 May 2008
- North Wales
9 out of 10 people buying a Maserati will want a nice sounding petrol engine so i guess that's why its only 9k?
The audience for a car with potentially eye watering performance car running costs with a very ordinary diesel engine along with the usual Italian car quirks will be vanishingly slim but if you're one of them then fair enough.
Just make sure you do go in with your eyes open, get actual quotes for the normal maintenance you'll need to be doing, after some research you *might* find you can quite happily run it cheaply if you can source all the right parts and are happy to do the leg work rather than just taking it to the dealer to 'sort out' whenever it needs anything.
It'll be slightly like owning an American or Japanese import car, if you want to do it even semi sensibly you'll be spending a lot of time on forums and car parts sites cross referencing part numbers to get the bits you need without having to pay an arm and a leg for them. Totally doable (i've done it twice with 2 Japanese import cars) but it is something you need to take into consideration when you go into it as it is a far bit of effort and you have to be fairly savvy.
Maybe factor in a trickle charger OP?
