Do you mean you get no screen giving you the option to enter bios?So I’ve had a few 9070’s and never had this problem. Right now I have a 9070xt prime.
I can’t get into bios and it’s not showing the windows install screen.
Any ideas on how to sort this out ?
Forgive me if I'm mistaken, but don't you have a few PC's in your household? A son has one IIRC?
I'd be trying it in another PC.
It’s just like there is no display outputDo you mean you get no screen giving you the option to enter bios?
Yer that never enter my mind good call.
No with the igpu it boots I now have windows installed. When I go back the 9070 I get windows login sound just no image.
Bios is now up to date and it’s still the same.
Upon testing in different systems I’ve found the same behaviour it will randomly work, but I’ve now also noticed on the times it fails to work the fans don’t spin up on the gpu at boot.
I now believe I’ve found my first faulty B-Grade gpu
Saves so much time in situations such as this!
