- 6 Sep 2016
By the way, good idea to make some backups if you haven't already. Enabling secure boot and TPM can lead to Bitlocker/Windows Hello shenanigans.
I just watched the dan video about that lol
Can you do this easily to upgrade from Windows 10? I’m a little unsure as there is so much conflicting advice out there!!I've installed Win 11 in all kinds of old hardware. You just need to mKe a usb stick as you can't use the upgrade
assistant. You can then either boot from USB for fresh install and do the reg key trick during install, or set a reg key in windows and run the setup from the USB.
Yeah, I did it on my Dad's laptop. Just create installation media or extract the ISO to C: and go in sources folder and run setupprep.exe /product serverCan you do this easily to upgrade from Windows 10? I’m a little unsure as there is so much conflicting advice out there!!
Awesome, thank you. That sounds like an easy fix, rather than some of the stuff I’ve seen elsewhere!!Yeah, I did it on my Dad's laptop. Just create installation media or extract the ISO to C: and go in sources folder and run setupprep.exe /product server
