Bf6 optimisation questions
8 Mar 2024
liverpool
Hi guys just a quick one just started playing battlefield 6 and was wondering what settings use guys use for graphics. I’m trying to research’s what is best for lower latency etc. share your settings of you like and your thoughts.
For latency, having adaptive frame settings correct and reflex active are most important. Turn graphics down to minimum required to hold a stable frame rate and don't touch frame gen with a barge pole
Appareny reflex is broken in this game atm? What’s best anti aliasing settings?
If you’re wanting to lower latency to give you a competitive advantage and it’s your first foray into BF6, then just putting some hours into the game is going to be far better.
Adjust graphics to make things cleaner and enemies more visible on screen, keep frame rate stable, absolutely.
Theres a setting which relates to render distance, I'd recommend setting it to overkill as I'm sure it was making things 'fuzzy' at a distance. I feel like the game is relatively quite well optimised.
Run on high for better visual clarity the game will still look excellent , turn off every motion blurr / film grain , raise fov to about 110-120
you can still turn down more settings but that will do for starters
