I've just bankrupted myself after buying an LG G5 after contemplating a G4, since I bought this house, literally a year ago this weekend.
What I didn't realise, is the wall I was going to mount it too, and all the walls in fact, have a slight cavity with plasterboard, for what I can only assume is for insulation purposes.
Where I want the TV, the stud is running directly through the middle, so I should be able to get the middle bolts in that. Will it be ok to use the spring toggle bolts for the sides. From some googling, it seems that quite a few people have mounted it entirely with the spring mounts, but I'd rather have some peace of mind knowing it's on a stud.
I think the gap between the brick and the plasterboard is only around 2" maybe 4", so I maybe able to some sort of long plug and bolt into the brick work?
I don't really want to cut the wall to bits if I have to, and certainly don't want some plywood behind it, as it won't sit flush.
Any ideas greatly welcome!
