Hi all
I picked up a prebuilt on a decent deal last week which I'm thinking of moving into my current case, as I really don't like the case it came in and it's also huge!
The AIO would only fit at the front of my current case, and I suspect might mean that the new GPU doesn't actually fit, so I'm thinking I might use my Dark Rock Pro 4 instead. I'm also wondering whether my RM750x would be good enough for the new build.
Current spec:
CPU: 5800X3D
Cooler: Dark Rock Pro 4
GPU: 3080FE
Motherboard: MSI Mortar Max B450
RAM: 32GB (2x16GB) Kingston Fury 3600Mhz
SSD: 2 x WD SN550 1TB
PSU: Corsair RM750x
Case: Fractal Meshify C, with 4 x 140mm (2 front intake, 2 top exhaust) and 1 x 120mm (rear exhaust) fans
Prebuilt spec:
CPU: 9800X3D
Cooler: MSI A13 360mm AIO (top exhaust)
GPU: 5080 MSI Ventus 3X OC Plus
Motherboard: MSI Pro B650-S Wifi
RAM: 32GB (2x16GB) Apacer NOX 6000Mhz
SSD: WD SN3000 1TB
PSU: MSI MAG 850GL
Case: Generic case with 3 x 120mm intake and 1 x 120mm exhaust fan
Any advice appreciated, thanks!
Current spec:
CPU: 5800X3D
GPU: 3080FE
PSU: Corsair RM750x
Prebuilt spec:
CPU: 9800X3D
SSD: WD SN3000 1TB
PSU: MSI MAG 850GL
