- 30 Dec 2017
Evening everyone.
I recently purchased a 5070 TI to upgrade from my existing 3070 TI. After installing and connecting the power cables, I turned it on only to find I had no display.
Opening up my case with the PC on showed the red VGA status light on my motherboard was permanently lit up. So I did the following:
Re-seated the GPU
Cleared CMOS using jumper and then taking the battery out for 30 minutes
Checked to see if there were any loose connections
Tried leaving the PC on just to see if there were any changes after a few minutes
No change, so I laid the PC on it's side so I could get a top down view of everything and noticed the GPU fans weren't spinning and wouldn't spin on boot.
I figured even if the GPU has a 0 RPM mode that it would still briefly spin on power up but it didn't.
Assuming there was some power issue, whilst the PC was on I simply pushed one of the 8 pin connectors that goes into the 12VHPWR adapter together slightly and the fans immediately kicked into gear.
I turned the PC off, turned it back on and low and behold everything was working fine and loaded to desktop.
At this point my pc only had the display attached and a keyboard in another room, so I powered it down, took it to my room, turned it on and..................fans don't power up and the red VGA light is back on.
So, I fully took that PCI-E cable out of my PSU, connected a new one and wired the GPU back up. Still the same problem.
It will sometimes spin the fans up if I move the PCI-E cables around particularly at the connection point to the adapter.
At this point I don't know if I am unlucky with multiple faulty PCI-E cables, a faulty 12VHPWR adapter or a faulty GPU. I contemplated buying one of those Corsair 12VHPWR PCI-E adapters for £20 (grrrr).
I'm going to reconnect the 3070 TI tomorrow afternoon and see if that works. If it does, then I'll be out of ideas.
Re-seated the GPU
