Paramo. Montane for a more high profile brand. But paramo is the one I'd recommend for UK clammy wet weather
Go look up Goretex pro shell prices like arcteryx nowadays that are then also only expected to last one season. Paramo lasts indefinitely, and can be repaired one panel at a time.For £250 I'd expect it to have a built in subwoofer (or two)
www.thrudark.com
But yes generally I agree, they're not cheap. Op never posted a budget.
Carinthia Online-Shop | Carinthia Webshop
www.carinthia.eu
Carinthia jackets - good for -40 warfare as used by the Royal Marines.
(Brownie points for knowing why I didn’t put any units on the temperature)
Is your dog fairly docile - neighbour has a young retriever who will jump up and would easily snag/hole goretex's I use daily for cycling
- so may want to consider whether shell clothing is resilient.
sounds like rebirth of rebranded buffalo clothing brandParamo.works for active people hiking say 6 hours in rain and showers wearing technical base layers that don't mind getting wet. For short walks wearing casual clothing underneath you get very wet.
I have had some good stuff from Decathlon recently, so just for a short time in the rain, I'd recommend something <£100 there. Goretex is nice, and others here have covered its uses well. I have Arctereyx and Rab jackets which are great, but for dog walking it's probably overkill. Temp regulation should be easy for dog walking compared to sport/exercise, so another reason not to spend out.
My recommendation a few posts ago is flexible in this sense too. It's flexible that the jacket can be worn in the warmer months on rainy days, just reduce the number of other layers you wear underneath obviously.How much do you want to spend?
All ill say its, don't get an insulated one, otherwise you can't wear it in warmer months
+1He probably did not expect to ask his family for a 400 quid whip round either to walk the dog.
I have a tough mountaineering shell that cost south of £60 from mountain warehouse ten years ago. It's is waterproof, weatherproof and tested to -10C plus windchill at 1000 metres by me. Not just a walk in the woods. A breathable waterproof goretex 15000 shell at less than a hundred quid with one or two fleece underlayers at fifteen to twenty quid will easily do for four season walking the dog in this country otherwise the dog may turn up its nose if the weather is so extreme.
Oh goody it's Christmas.
+1
Some of this pricey gear that's been recommended is good and all if you're going on long technical hikes or other long distance/challenging stuff, but for walking the dog in the woods for a couple hours, it really is overkill and expensive.
Just pop down to your local tk maxx, I picked up a columbia rain coat from there recently. No padding, I prefer to layer up.
They also sell helly Hansen stuff…
