Wanting to try Linux
15 Oct 2016
I am seriously thinking of trying Linux not something I have used before. I am very familiar and fluent in both windows and Mac OS. But never tried Linux, just wanted to have a go and see what all the fuss is about.
Was thinking of doing a dual boot so I can still use windows 11. Admittedly if I was to every move over fully I would want something I can daily drive, mostly gaming, internet and the occasional office document. I don’t use office, I currently use Libra. Been told Ubuntu is a good place to start also been told that Bazzite is good for gaming.
Anyone got some good recommendations, or is best to dive in a learn hand on with it?
If you just want to mess about I'd probably use VirtualBox in Windows - I wouldn't start dual-booting unless/until you commit more to it.
Zorin is a nice transitional OS. It’s underpinned by Debian which is what Ubuntu sits on. Well polished. Good apps for getting yourself used to Linux.
I would just stick it in a virtual machine to mess about with. If you want to take it further then set up a dual boot
Ignoring any niche outliers such as LFS, Gentoo, Slackware and a few others - the majority of Distros are going to be mostly the same to every-day end users. Don't fall into the trap of distro-X is better than distro-Y - there are small differences here and there and some have pre-config done more for other things, but any of the big ones are going to be fine. The majority of them are just custom packaged Debian in reality.
Bazzite would probably be my first foray into linux nowadays. I do think that Linux would cover most peoples daily needs (assuming no need for kernel anti-cheat and some specific apps (adobe)).
However there are still many paper cuts and things work differently so I believe you have to actually want to use it (or just want to not use windows) in order to look past those papercuts.
Ive been almost exclusively Linux based (bar bf6) for a few years, use mac/chromeos and occasionally windows at work and vastly prefer my Linux desktop to all the others.
As for should you install on a VM or whatever, if you have all your docs in cloud or something Id just say go for it and wipe off windows, installing windows is pretty simple now if/when you want to go back.
I am definitely more in the I don’t want to use windows / Microsoft camp, one of the reasons I use Libra office instead. I jumped over to mac years ago because I couldn’t stand windows 8. I liked 10 enough it come back and it was the best solution for my gaming PC I wanted to build as gaming on mac was a pain.
At the minute I am thinking of giving it a go in a virtual box and see how I get on with it. Gives me time to seriously think it over as, whilst I play BF6 and maybe change over once I get bored of it.
BF6 is the only thing keeping a Windows partition on my machine, else I'd be vanilla Debian all day long these days.
Fortunately Arc Raiders seems to have the attention of our gaming group and that runs tremendously well under Linux.
edit - AMD GPUs are far easier to get up and running, although Nvidia isn't insurmountable. There are plenty of guides out there. Also depending on your board you might have some compatibility issues to work around with various BIOS settings etc. Power states and USB devices have taken a little bit of tweaking to get stable, as well as RGB stuff (mainly so I can turn it all off) but again it's a fairly well trodden path.
I've used Ubuntu in the past, but not for over 10 years.
Just done a full new build and have installed Bazzite in the hope of abandoning Windows entirely.
So far so good, although I've had a few niggles getting things up & running;
- 1 problem with updates (because I created a new admin and deleted the default... Not sure if I missed the installer configuration option for this which would have prevented that). Fixed by sorting permissions of a folder using a guide.
- 1 problem getting Dirt Rally to run fixed by changing the proton version it used
In general though, it's been as slick as I'd have hoped and the gaming experience is infinitely better than it was last time I tried Linux.
Been running Bazzite as a daily for the last few months, and it's been relatively painless to switch over. A few issues with software for peripherals (many hardware vendors have zero Linux support), but nothing insurmountable - the only real bugbear I have is the lack of HDR support
HDR worked fine last time I tried it, had to turn off KWin tonemapper tho cause it was messing with RenoDX but aside from that can't remember having any issues
It works fine in desktop, but seems very hit and miss with games :(
Are you running it in gaming or desktop mode? I have read that it works a bit better in gaming mode, so I might try rebasing at some point
Be prepared to needing to Google search like **** in order to do anything, including installing, well, even downloading the install file isn't a single click affair.
Then you'll find out there's a million different commands to do the same thing.
It'll need to be a labour of love imo.
Desktop and game mode (so gamescope), pretty much I was having issues getting RenoDX to work on Cachy, it just didn't look correct compared to windows, I changed distro to Bazzite and gamemode was fine but desktop wasn't, I then found out about KWin now having a tonemapper, after disabling that it was fine and worked same as windows
Now this was with AMD, if your with Nvidia you'll need the vk HDR layer to get HDR properly working
In end I've just gone back too windows for now tho, I don't really want to be with AMD and lose out on Nvidia features, and 24H2 LTSC works good enough until the VKD3D fix comes in the future
I'm full AMD, I'll have a look into KWin when I get a chance, thanks :)
This is the AI version which I'm not a fan of but it does work
Create a new configuration file in the /etc/environment.d/ directory using a text editor with root privileges. You can name the file something like kwin-tonemapping.conf.
Add the following line to the file:
KWIN_DISABLE_TONEMAPPING=1
Save the file and restart your computer.
