Logger: homeassistant.components.recorder.core
Source: components/recorder/core.py:896
integration: Recorder (documentation, issues)
First occurred: 2 December 2025 at 17:46:29 (1 occurrence)
Last logged: 2 December 2025 at 17:46:29
Unrecoverable sqlite3 database corruption detected: (sqlite3.DatabaseError) database disk image is malformed [SQL: UPDATE states SET last_reported_ts=? WHERE states.state_id = ?] [parameters: (1764696685.2828643, 442326)] (Background on this error at: https://sqlalche.me/e/20/4xp6)
Traceback (most recent call last):
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 1963, in _exec_single_context
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/default.py", line 943, in do_execute
sqlite3.DatabaseError: database disk image is malformed
The above exception was the direct cause of the following exception:
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 896, in _process_one_task_or_event_or_recover
File "/usr/src/homeassistant/homeassistant/components/recorder/tasks.py", line 297, in run
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1192, in _commit_event_session_or_retry
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1218, in _commit_event_session
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/orm/session.py", line 2365, in execute
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/orm/session.py", line 2251, in _execute_internal
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/orm/bulk_persistence.py", line 1627, in orm_execute_statement
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/orm/bulk_persistence.py", line 357, in _bulk_update
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/orm/persistence.py", line 912, in _emit_update_statements
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 1415, in execute
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/sql/elements.py", line 523, in _execute_on_connection
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 1637, in _execute_clauseelement
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 1842, in _execute_context
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 1982, in _exec_single_context
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 2351, in _handle_dbapi_exception
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed
