Looking for advice for a new build please.
30 Mar 2009
Purchase Timeframe: Ideally i would like to order before the new year, end of January at the latest.
Budget: £2000-£2500
Usage: Pretty much only gaming
Preferences: Currently strongly leaning towards a 9800x3d with a 9070xt, 32gb ram minimum,
Current Hardware: i7 8700k, 1070ti, 16gb ram ddr4, asus rog strix-z370f
Peripherals: not required
Special Needs/Requirements (inc Wi-Fi): nothing
Any help would be greatly appreciated, i am so out of touch at the moment, its been probably over 8 years since i built this last one. My current build will be my son's first computer, which is more than capable for the games he plays, but also can help him upgrade as time goes on. Thank you all in advance.
Currently a 9800X3D is your best bet, with that budget though I'd hold off for the 9850X3D as you're probably 'only' looking at £1,500/£1,600 for your existing requirements. For gaming 32GB is plenty but on OCUK almost everything is out of stock.
There are some good recommendation in this thread (with a few variations on the CPU/GPU) https://forums.overclockers.co.uk/threads/5070ti-build-for-1-5k-inc-monitor.19007616/
GPU options are likely the 9070XT, 5070Ti or 5080, it really depends on how much of that budget you want to blow. Personally I'd not be paying a grand for a 5080 at the moment due to rumours of the supers being released (assuming RAM pricing hasn't killed that idea) A 9070XT/5070Ti if you use RT are good 'cheap' options leaving you with budget left over for a little upgrade down the line.
For a gaming PC there's not much special about it, just grabbing a few bits that support the 9800X3D/9070XT you wanted.
The problem is RAM, trying to find something in the 32/48/64 variety that doesn't cost more than your CPU/GPU :o
Peerless assassin is cheapest cooler I'd pick, but case can support a 360mm AIO if preferred.
My basket at OcUK:
Total: £1,567.85 (includes delivery: £11.98)​
Not a lot of parts to choose from at the moment unfortunately, you used to be able to get a good Thermalright 360mm AiO for £40 and there's a severe lack of good air cooler availability too.
You should be able to find the Thermalright Royal Pretor for £40 and it competes with some 360mm AiO's, but be sure to measure up your case and make sure it fits.
No guarantee the memory I've listed will work at listed speeds, however you should be able to manually dial in 6000/c30 on it without a problem, funnily enough it's one of the cheaper 32gb sets available on OCUK at the moment.
M-ATX build as that's a preference of mine:
My basket at OcUK:
Total: £1,864.60 (includes delivery: £11.98)​
V2, are these old enough for a V2! :o
I went digging.
I have asked Phanteks, and here's their reply:
"Although the PSU has mostly stayed the same, there have been these 3 changes:
  1. For the 24-pin and the 12V-2x6 cable, the cable combs will come pre-installed.
  2. The PSU will run in hybrid mode by default, so the button has hence been removed.
  3. The 12V-2x6 connector now has our signature color, so you can easily see if you've plugged it in all the way.
We hope this answers your question."
Based on their response, the underlying PSU platform appears to be largely the same, but it has been updated to a newer, improved revision. Additionally, the connector layout on the PSU has also been revised. Overall, all these changes are for the better.
I was wondering the same and couldn't find any reviews. So I got the Phanteks AMP GH V2 1200W and the only drawback I noticed is that the fan is very loud. It doesn't spin during light usage, rendering the PSU very silent in general. But once it starts spinning, it sounds like a jet engine and is very annoying to be honest.
The new revision (V2) doesn't have a hybrid mode switch. It operates in hybrid mode all the time basically.
Why do manufacturers always have to "improve" popular/competitive products? :confused:
I went digging.
More like "downgrade" while making people think it's an improved product unfortunately.
There's also the FSP Vita line which seems to be decent from what I've read at the current price point, slightly more compact design than most.
My basket at OcUK:
Total: £123.98 (includes delivery: £3.99)​
There's sweet FA to really choose from at the moment for almost everything, I don't remember it being this bad since lockdown.
I'd personally be willing to take a punt at the FSP, they seem like a little known company but tbh they're the OEM for a fair chunk of the big names out there.
Seasonic's Core GX is an option while it is on offer, though the innards are definitely a stepdown on the Focus, or the Vertex derived HCG Pro. Vita has better caps, not sure about the rest.
I saw one review about the Vita's fan being so-so, not terrible but not great either.
It's all going to be trade offs unless spending silly money for the most part at the moment I suspect, probably wont get much better anytime soon either.
Shame Asrock came into the PSU game with such aggressive pricing or they'd be a solid option, although the Steel Legend offerings aren't too terrible while having a look around at what is actually in stock:
My basket at OcUK:
Total: £157.94 (includes delivery: £7.99)​
Seems like a good option from reviews, I believe HEC is the OEM, 10 year warranty.
This is for the 850w version: https://www.kitguru.net/components/power-supplies/zardon/asrock-steel-legend-sl-850g-psu-review/6/
Seems like the biggest complaint anyone has is that it doesn't magically offer anything new, which makes zero sense to me as it's a bloody power supply.
hmm, i never close my cart down from a few days ago when someone was looking a 216...it still has bf discounts on it and when i go to purchase doesn't update with new prices..wonder it that would actually go through if i clicked buy :cry:..oh so tempting
My basket at OcUK:
Total: £1,255.86 (includes delivery: £11.98)​
as a guide, another place still has bf deals
the 1050w montech Centery II fully modular pcie5 80plus gold atx3.1 is £89.99, 1200w version is £109.99
both are A rated
or the 1200 NZXT atx3.0 is £119.99 which is A+ rated..think from look it's 2023 model rather than 2024 model, but still A+ rated...idenetical apart from atx3.0 to atx3.1 which i think is slight difference inb the cable
My basket at OcUK:
I'm snobby about HEC, but yeah, it looks like they did a good job!
The Vita you mentioned has a 10 year warranty too, unlike the Core GX (7) or the Amp GH (8).
They used to be the master of making weird boards that nobody else did (like AGP+PCIE, multi-DDR), so maybe that's where the expectation comes from?
Somebody on here had some RAM that was only £130 and it worked :D
Those other parts are better buys, but not like RAM where it doubled/tripled.
Aye, the Vita seems the best option IMO with currently available stock.
10 year warranty, good platform, excellent prices by comparison.
My basket at OcUK:
I love that case, they need to pop out an M-ATX variant.
My basket at OcUK:
Hi, would you possibly have any suggestion for case without Tempered Glass?
maybe something like
Kolink Tranquility Silent Midi Tower Case - Black Noise Dampened
RAM wise, im not paying the expensive prices ive seen but i might go for:
TeamGroup Vulcan EXPO 32GB (2X16GB) DDR5 PC5-44800C40 5600MHz Dual Channel Kit - Black (FLABD532G5600HC40BDC01)
gives me hope of arriving some point in q1 as its pre-order
Yeah, that's one I often suggest for no window/glass builds. Phanteks also do a solid panel for the XT. There are still a few cases with acrylic windows (Enthoo Pro v1?).
Looks alright. Hunting for RAM is not easy.
thank you kindly Tetras appreacaited.
im really not interested in rgb or a viewing window. im more utilitarian and function.
Indeed Ram isnt easy at the moment :/
As long as you turn the rgb off, most cases will do.. I have a corsair 5000X. the glass is heavily dark tink, so with rgb on, you just see that, with rgb off (if i need to concentrate), it just becomes a completely back monolithic block..you cant see in at all
below some other option
although the 011 miniv2 is glass front and side, this is the non rgb version so comes with 5 non rgb fans preinstalled, so either put a 360 aio in top, or a air cooler and s/b good to go, though with air cooler I'd prob stick one for 120 exhausting out back...it can take a atx mobo as well, but is far more compact than the standard 011d evo for exmaple. think once you put in a black mobo with non rgb ram etc, you wont be seeing much
below that is the matx A3. has wood slats on front (with mess to allow air thru) and put the one with mesh sides. does not take a atx mobo, so matx. can take a standard psu though (fans not incl.)
below that is the fractal north with wooden slats down front and mesh side..from look glass panel side looks quite heavily tinted as well so don't think you'll see much through that anyway (comes with 2 frontr 140 fans included)
but pretty much any case will do, just don't turn rgb on if you don't want to see..but anyway, that's 3 different size cases that look nice imho, though cases are a lot of personal taste
[*] 1 x Lian Li O11 Dynamic Mini V2 Flow Midi-Tower Case - Black (SKU: CAS-LIA-05356) = £83.99
[*] 1 x Lian Li A3 mATX Wood Edition - Black (SKU: CAS-LIA-02630) = £69.95
[*] 1 x Fractal Design North Charcoal Black Mesh Mid Tower Case - Black (SKU: CA-0AU-FD) = £126.94
[/LIST]
Total: £930.86 (includes delivery: £0.00)​
thanks @Craig_d1 . appologies im jsut noticing your reply now.
i'd go with a
Lian Li A3 mATX Wood Edition - Black​
i do like the look of it.
i just dont want the hassel of glass in my case. and rgb holds no interest for me, i need it to work not look pretty, and in darker settings it becomes more of a distraction and annoyance. but i get what you mean on turning RGB off.
i'd go with a
yeah, below is the corsair 5000x when everything is turned off (ie when i need to work)..the tint helps but get the idea how most cases would be
let me know how the a3 matx build goes. I've never built in a small case but that case does look smart...would go well in our office here
...cheers for heads up ..Will put another photo up tomorrow
