Best Mesh System?
22 Nov 2004
London
Hello!
I'm currently running a Mesh system using Linksys Velops. I've found them a bit unreliable (dropouts/ failure to recognise passwords etc). And I also want to get really granular control over internet access to limit devices to certain times only, or to restrict content. I also would like to be able to create separate VLANs if possible.
Would appreciate strong recommendations! Thanks!
Interested if anyone has any advice here too. Reviews and real world reviews seem so mixed for so many systems. I need to replace my now ancient setup as it occasionally has failures.
There is so much choice and it comes down to budget, the speed and features you want, I doubt there is a right answer, In addition the failures might not be solved by new gear if the problem is your environment rather than the hardware. Typically the best answer is to wire your APs for robustness if your environment is the issue.
I have been running both ASUS BQ16 and some BT10 for a year, using Asus Ai mesh, reliable, zero issues, apart from price :D
They do have cheaper devices but I have no first hand experience.
This guy has compared them
Thanks - wow this series is super pricey but maybe worth the upgrade. Food for thought - thanks!
I've got 4 Deco X10's. Bought them in a bit of a rush and without much research when we moved to a house with 2 ft thick walls.
They're not for advanced users (i.e. you can't split the 2.4 and 5ghz SSID's), but they have been pretty reliable, no dropouts etc. Ethernet backhaul on one of the units, connected to my old switch with no issues.
Hello!
Yeah as mentioned, run of the mill mesh systems like TP-Link, Eero, Orbi, etc are not going to give you any advanced controls. They are basic admin and are more just plug in and go. Asus does offer a lot more features, but they are not great for security and often you pay a premium for the name. Although Netgear Orbi kit isn't exactly cheap.
If you want that granular control then something more in the AP space might be better, like Zyxel Nebula or Ubiquiti Unifi. But that involves Access Points and not mesh.
You might be able to do some more controls by sticking with Mesh and potentially putting something like a Firewalla in the mix.
Wi-Fi settings, Advanced, band… then knock yourself out. Equally you could just add an IoT 2.4Ghz only SSID if you prefer.
ASUS are a garbage tier OEM with more ‘Oh hell no’ moments than any reasonable company should ever have.
If you want good, Ubiquiti, Omada or Aruba are options, but you need to run local management of some description, for simple mesh, I really like Deco, it’s what I put in for friends and family as it’s inexpensive compared to UniFi and idiot proof. Literally the only calls I get on Deco installs is where someone unplugged a node, that’s why I recommend the range.
Thanks for that, either that's a recent software update or I'm blind. Could be either to be honest :o. Thank you :).
Going from memory (always dangerous), it wasn’t a thing in 2023, but was in 2024, I think around the time they let you add guest and IoT as opposed to just a guest network.
I'm looking for a new mesh system too, currently using the Deco X55. Fine when using wired backhaul but the third node had to be wireless backhaul and it's been a massive PITA, (they even sent me a beta firmware for it). Looking for something that is reliable with an actual working wireless backhaul.
Moved from deco P9 to the deco xe75.
It’s really good, I had areas I could only get half speed with the p9. But full speed with xe75.
For whatever reason it slower in the attic, every other room is better.
I've had the TP-Link Deco S4 (3 nodes) for 5+yrs. Cheap but solved all my issues with steel beam in the kitchen and Wi-Fi speeds around the house. Wanted to work in the kitchen and garden when WFH. Provider is VM. It's been sold for me.
I had been though a few family parental firewall devices before this and tbh this had enough for me to ditch all that. Different users profiles, weekday and weekend curfews, white lists, black lists age profiles. Mobile app. Usually stats. It's a little basic but enough for me.
Need to install a firmware update and reboot maybe twice a year. Occasionally someone unplugs one.
I've a console and gaming PC on powerline adapter because that seems to have less lag than the mesh. Even if the mesh download is quicker.
I assume newer more expensive mesh must be better. No real demanding gamers in the house. The adult kids do have the odd "lan" session with their mates. Mostly undemanding titles.
Probably time for me to upgrade everything. WFH a lot been reluctant to switch.
One issue I did have was with some of the pixel phones weren't being identified. Some VPN in use. But an update fixed that. I can usually track it down with Mac addresses or trial and error.
I was using a couple of netgear RB770’s. But the software was very limited honestly. And caused issues with some devices. So I sold them.
Now I’ve got three Eero Pro 7’s placed around my home. All with full signal to each other. Couldn’t be happier. They’re not the cheapest though ! Speeds good. Software is good. Super simple setup. And all my devices connected instantly when using my original network id/pw
I recently updated my Orbi 850 to a 970. Been very happy with it but I’m not using any advanced Vlan or restriction features - you would need to check that out, but it does have a dedicated IoT setup.
It was very easy to setup though and coverage, reliability and speed are great so far. I’m using mine in access point mode to link different parts of the house and it’s using both 5 & 6ghz bands to backhaul and happily pushing our 1.15Gbps internet connection through a brick wall at about 10m separation with no loss of speed.
As others have said though, not cheap!
