Its not something you need to set at your end at all just their end, From their portal thing services -> my services -> choose your broadband, then on left is a change options button. Should be able to enable it there, might need to reboot your router to grab the static ip if its different than your current one.Noob question, Aquiss has static IP address, is this something you have to request if you want one?
Im looking on my routers Eero app and under WAN type PPPoE is selected and there is another option for static IP. Can I choose this over using PPPoE?
Im just curious really I don't have any need for a static IP.
Just a little heads up, there's a four line limit on text signatures (and image size restrictions) here. You may wish to edit your signature before one of the Dons (mods) sees it and 'fixes' it for you. Welcome on board.
