BT don't offer symmetric its an alt netA little confused, happens a lot. But is that a BT type FTTP or another type of FTTP connection?
Up until you brought it up I didn't realise it was Highland Broadbands (Lothian Broadband) own network so apologies for posting in the wrong thread. Up to 942mbps upstairs now. Wifey's pc which is next to the router is getting 986mbps!!
It's on the way: https://www.ispreview.co.uk/index.p...ec-for-future-5-5gbps-and-8-5gbps-speeds.htmlNo worries. I was just getting s little excited in thinking / hoping that BT had started trialling some symmetric type connections![]()
But how much it gonna to cost?
2.5/2.5Gbps would be ideal
I think its just a standard catchall message that means diddly squat other than we may get around to your area someday, maybe. I get the same message.Edit: It's back to showing "We're building in this area now"![]()
Openreach checker says FTTP 1600Meg down and 115Meg up. BTw checker says FTTP 1000Meg down and 220Meg up. Zen Internet checker says FTTP 910Meg down and 109Meg up. EE checker says FTTP 1600Meg and 115Meg up.
Who are correct?
Who are correct?
It's recently changed to "We’ll be building in this area in the next year". Kind of seems more realistic, there's been no further works since about October, so I'm guessing there must be some issue that needs to be solved. Bit annoying as probably less than 100 meters away, the houses there can order it. They are pole fed though compared to ducted (at least in the pavement) that this bit is, so I guess that was easier to get ready for service.I think its just a standard catchall message that means diddly squat other than we may get around to your area someday, maybe. I get the same message.
