- 29 Aug 2010
- Cornwall
He'll be using fake frames next to go with the fake resolution! :-DSo what happened to upscaling is no good and you only using native?![]()
DLSS2 was a couple of years ago, that's why, being less ***** than FSR2 didn't mean it was as good as made it out to be.Cracks me up as he was so against it a couple of years ago![]()
DLSS2 was a couple of years ago, that's why, being less ***** than FSR2 didn't mean it was as good as fanboys made it out to be.
Doh but ty for tryingTurns out i can't go in to Dog Town yet....
I ran about 5KM for nothing
You guys make me laugh. Pointless debating in this thread as mods will be along soon once you summon them to delete it all anyway![]()
Doh but ty for trying![]()
But if you do want to unlock it then do the quests helping Judy to find Evelin then you get the quest to go find the Voodoo Boys then after that you should get a message from Somi asking for your help which unlocks dog town.
Or you could just start a new game and skip all the other stuff and just go straight to the Phantom liberty content![]()
Will need to try this myself, lost a lot of faith in HUB and TPU send to think it's really good. Not really bothered about it but I did use FSR 3 framegen in stalker 2 on my 7900GRE and it was very good so can't imagine this is worse.
HUB pointed a 960fps camera at the screen and have hard evidence that the frame pacing is mostly broken.
Interesting... HUB have the most negative take I've seen so far.
Genuine question; if it's only really noticeable with a 960fps camera, then is it really a huge issue...? That could be why others have not (yet) reported on it.
I never do that.... its not me when that happens, seriously.![]()
they need to make the next frame first then the fake frame is kinda an average of the 2I'd assume the fake frame is done immediately. To have a smooth cadence with VRR, they'd need to predict how long the next real frame will take and insert the fake frame at estimate/2.
Think it's just because he was testing it with VSync disabled for some reason AMD frame gen doesn't work properly with out VSync, TBH as far as frame gen goes for me at least AFMF2.1 in the driver always seems to work better might have a slight loss to image quality over FSR frame gen but it just feels a lot smoother.Interesting... HUB have the most negative take I've seen so far.
Please report back with your findings!
I always assumed it was you tbh. When you joined a debate, not long after mods turned up to delete it all![]()
