Glad you are happy with your purchase.
Unfortunately, I am not happy with mine. The Kiwi Design H4 Boost strap is like the Bobo S3 but without any fan or swappable batteries. First impressions haven't been great.
I am comparing the H4, a halo type strap to the BinBok T3, an elite type strap.
The H4 is well built and looks great. It's well balanced, there is a nice feel to it. I was looking forward to trying it on. Once I had it on my head though, that's where it went downhill.
The problem is that it always feels loose on my head. I can tighten everything until it's actually hurting my head, but it still feels loose. When I look down at anything it feels like it's just about to slip off.
Then there is the problem of fitting it on. With the Binbok T3, once you get the top strap dialled in, it's easy to put on and take off. With the Kiwi H4, I have to adjust it every time I put it on so that it sits right.
Not having a swappable battery is a negative too.
Kind of sorry I bought it now. But haven't had much time to test it yet, will try it out more over the next couple of days. At the moment, I am pretty sure I will be returning it.
Do you think the temple foam pad mod might help with the feeling of looseness?
Quest 3 accessories thread
Bought the Kiwi head strap and the Stand the charger stand that goes along with it, Great bit of kit the head strap is super comfy.
