New PC build - saving/migrating games data?
20 Oct 2002
London
I'm staring at the new components for my lovely new 9800x3d and 5070ti build and getting everything prepared today on my existing (soon to be old) system.
New build will have a 1TB NVMe drive for OS, and a 2TB NVMe for games. My current/old machine has a 1TB SATA SSD games drive with all installs/data on. That SATA will be going into the new build as a general storage drive, which is helpful because I should be able to port everything over to my NVMe right?
So, what do I need to do to ensure I keep all my save games (and preferably make the game installs work without having to redownload everything)? Save games I care about currently are;
Rockstar Launcher:
Red Dead Redemption 2
Steam:
Counter Strike 2
Dirt Rally 2.0
Metro Last Light
EA:
Battlefield V
Epic:
GTAV
Thanks for any pointers, I'm guessing all of the launchers do things slightly differently :o
You don't even need to do that, leave them where they are and just point Steam to the folder the games are in.
You mean (1) install new Steam instance on the new NVMe drive and then (2) point it to the SATA drive? I don't want to be gaming off the SATA drive.
You can copy to your NVME if you want, but real world difference in gaming between SATA and NVME is really not a lot if anything. if it were me, I'd leave where they are and use the space on your main drive for other stuff. Maybe games that use that direct storage on the fly loading could use the NVME, but unless you're doing very large file transfers, you'll probably not see a difference between the two.
Well contrary to popular opinion nowadays I did buy an extra NVMe drive for games so I'd prefer to use it :) To clarify on the new machine I'll have;
- 1TB NVMe for Windows, docs etc.
- 2TB NVMe for games
- 1TB SATA SSD for any other storage
Just copy them to your drive of choice, then point Steam to those folders and you'll be good.
As an aside, I'd use your SATA drive for your documents if storing locally and obviously if these documents are important to you, also store them in the cloud or on a mechanical drive that is offline most or all of the time.
Thanks. What about Epic, EA, Rockstar etc? Can you point them to your files?
Yeah I have Google Drive and a used NAS I need to build. I don't even have that much "stuff" to hoard, I could probably duplicate docs across all 3 drives for redundancy for now lol
This also applies. You should also copy over the \ProgramData folder and your Windows Profile (particularly the APPDATA folder).
Argh I just unplugged my old machine and took out the SATA drive ready for building tomorrow!
Please tell me those folders are somewhere in the Program Files (games install) path, or in My Documents. Those are the two things I backed up :o I'm guessing Steam saves game progress to the cloud right? I should be ok? I know Rockstar does.
Nope. \Programdata is c:\Programdata and is hidden. and your profile is under c:\users\username. Copy them both to somewhere innocuous then transfer over the contents.
