I was hoping to spend a quiet day in the house but this might be enough to make me jump in the car hahaAnyone been to ikea? I've done 400 quid on their outgoing zigbee stuff![]()
Blimey £400 on what ?
What ikea Zigbee devices do you lot have ?
Being pretty well covered has never stopped me from being tempted anywayI need to go to Ikea anyway, but probably not until Monday now. If there's anything left I'll pick up anything that might be useful. I'm pretty well covered for Zigbee stuff across the house anyway.
For use as a controller via voice or to use it as a speaker in HA?I’ve just had a right battle connecting my google nest to HA. I’ve got a ton of sensors to set up later this week as well.
I'd be interested in this...anyone know where to start with triggering HA automations from google home speakers?
Yes you can BUT each controller has to be tied to a different Zigbee “server”. In my own case I was moving from ZHA to Zigbee2MQTT so I plugged in the new coordinator, hooked it up to Z2M and the proceeded to remove devices from ZHA and add them to Z2M. I did this over a day or two.My SMlight SLZB-06Mg24 has arrived, can I have two ZigBee coordinators in HA at the same time as I'm wanting to change the channel the easiest way will be to remove each ZigBee device from the old one in turn and they should be seen by the new one then.
I'll just set it up on the garage for now then I'll run a cable somewhere central when I have the time.
