- 30 Jan 2020
Can't believe it's been almost 5 years since I last built a system, but now looking for an upgrade.
Currently in the basket is this build. Couple of notes though first
1) I have just selected some Liam Li fans - I know they are the reverse fans which I suspect I don't need and should have looked for the normal fans. I have chosen 4, three to replace the fans on the AIO radiator and one for the back. Should I use a triple and a single instead? I'm not up to speed on how these work, but I like the looks.
2) The 2TB NVME stick is not set in stone, I have others available of a larger capacity but wanted to factor in another stick
3) On the bottom of the case is going to be the 3 Noctura fans.
Anyone care to share their thoughts on the build, point out errors or maybe even make suggestions on changes? As for budget, this is hitting very close to what I want to spend as I'm also looking to swap out my current 49" monitor with a ASUS ROG Strix XG49WCR when they come back into stock (https://rog.asus.com/uk/monitors/above-34-inches/rog-strix-xg49wcr/) and that will be the last £1K of budget spent.
My basket at OcUK:
Thanks
Mark
My basket at OcUK:
- 1 x Lian Li A3-mATX Tempered Glass Micro-ATX Case (Black) (SKU: CAS-LIA-04811) = £59.99
- 1 x AMD Ryzen 9 9950X3D Sixteen Core 5.70GHz (Socket AM5) Processor - Retail (SKU: PRO-AMD-04501) = £619.99
- 1 x G.Skill Trident Z5 Neo EXPO RGB 64GB (2x32GB) DDR5 PC5-48000C30 6000MHz Dual Channel Kit (SKU: MEM-GSK-01357) = £599.99
- 1 x ASUS ROG Ryujin III 360 Extreme ARGB Performance Black All In One CPU Cooler with OLED- 360mm (SKU: COO-ASU-03398) = £369.95
- 1 x Asus ROG Loki SFX-L 1000W Platinum Power Supply (SKU: CA-05W-AS) = £239.98
- 1 x Asus GeForce RTX 5080 ROG Astral OC 16GB GDDR7 PCI-Express Graphics Card (SKU: GRA-ASU-03929) = £1,499.99
- 1 x Asus TUF Gaming B650M-Plus WIFI (Socket AM5) DDR5 Micro ATX Motherboard (SKU: MB-6K2-AS) = £184.99
- 4 x Lian Li UNI SL120 INF Reverse Wireless Addressable RGB Black 120mm Fan (SKU: COO-LIA-04663) = £27.95
- 1 x WD Black SN8100 1TB SSD M.2 2280 NVME PCIe 5.0 Solid State Drive (WDS100T1X0M) (SKU: STO-WDC-05312) = £179.99
- 1 x WD Black SN850X 2TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS200T2X0E) (SKU: HD-591-WD) = £209.99
- 3 x Noctua NF-A12x15 PWM Chromax Black Swap Fan -120mm (SKU: FG-07J-NC) = £23.95
Total: £4,148.51 (includes delivery: £0.00)
Thanks
Mark
SAVE 16%
£700
(incl. VAT)
£590
(incl. VAT)
MEM-GSK-01357
£900
(incl. VAT)
COO-ASU-03398
£370
(incl. VAT)
£210
(incl. VAT)
SAVE 6%
£1,700
(incl. VAT)
£1,590
(incl. VAT)
£185
(incl. VAT)
SAVE 14%
£28
(incl. VAT)
£24
(incl. VAT)
SAVE 16%
£320
(incl. VAT)
£270
(incl. VAT)
FREE DELIVERY
