- 5 Jun 2007
- extremes.spacious.indelible
Good luck. Hopefully something isn't bent. Could be a limit switch bent/missing? Can't remember (and can't be bothered to go look) how they've implemented limits on the mini. Hopefully it isn't done on strain (motor can't push it past actual stop and the resistance is detected as limit) as that could show there's a sticky point on the rail it's interpreting as the end.
A factory reset seemed to sort it, and new purge cutter arrived today
