- 19 Oct 2002
- Shakespeare’s County
But you could get a decent car with actual paint on?I wouldn't go back to EV even if I had a 350kw in my garage
M2 Comp incoming, nice paint job!But you could get a decent car with actual paint on?
No it wouldn't, I was driving all over the country, sometimes in freezing conditions?
ThxThen I suggest you set yourself up for failure.
When you could get home empty and leave with a full charge every day, I can’t see how that wouldn’t materially change the experience compared to public charging for all milage.
Even if it wasn’t enough to get you through the day every day you’d be taking a massive amount of time off how long you’d spend at any chargers.
I think it's fine to say it didn't work for youA lot of EV misplaced justification going on?
Like I said, it works for some, not for me.
Maybe his work takes him all over the country staying in hotels mid week? I know plenty of people who live out of hotels for two or three nights a week. While that 100% battery first thing on a Monday morning is great, after that you are in the realms of public charging and it becomes irrelevant to whether the car is right for you or not.
In short, why assume you know the guys life just because an EV works within your bubble?!
Great to see everyone is so on board with EVs being unworkable if you can't charge at home, roll on 2035 and two fingers to those without a drive.
If someone said they work all over the country no one's recommending them an EV or PHEV.
Quite obvious with a few questions no need to assume anything.
The work was a hypothetical but as you can see, driving all over the country.No it wouldn't, I was driving all over the country, sometimes in freezing conditions?
I'm showing 19 EV miles this morning from a reported 32 in the summer (but I have had 35+ out of it on multiple occasions). That was at -8C and after the pre conditioning running drawing 2kW from the charger but burning 5kW via the PTC heater (according to google).I was quite happy with my range this AM, especially as the car reported the outside temperature of -8
I get somewhere between 25-32 in the summer, and it was reporting as low as 15 this AM, but it did the school run on electricity only, as it does every day
How are the full EVs fairing, compared to summer temps? Is it as severe as I see on my PHEV?
Our PHEV battery range estimate has essentially halved - was around 36 most days in the summer, just checked this morning - 18 miles :E However, it's still enough that we can do most of our daily driving. And if I do a short trip early in the day, say a couple of miles to the supermarket, I will now plug the car in again when I get home if I know we'll use it later. I don't benefit from the cheap overnight rate, but it's still cheaper than petrol, especially as I'm just topping up.I was quite happy with my range this AM, especially as the car reported the outside temperature of -8
I get somewhere between 25-32 in the summer, and it was reporting as low as 15 this AM, but it did the school run on electricity only, as is does every day
As long as you're not charging it to 100 and leaving it parked up for more than a few hours you'll be fine.Our PHEV battery range estimate has essentially halved - was around 36 most days in the summer, just checked this morning - 18 miles :E However, it's still enough that we can do most of our daily driving. And if I do a short trip early in the day, say a couple of miles to the supermarket, I will now plug the car in again when I get home if I know we'll use it later. I don't benefit from the cheap overnight rate, but it's still cheaper than petrol, especially as I'm just topping up.
My only concern is that when we picked the car up, the battery was set to charge to 80% max. That wouldn't really be practical, so I just set it to 100%, but I do worry a little about whether that's going to be bad for the battery in the long run. But the car is only ever slow charged on the 3-pin, so I hope that might be better for it.
