- 20 Feb 2009
- Ashton-Under-Lyne
Recently I've been looking at how much power my home server uses, and with the cost of electricity continually climbing, I'm trying to work out if I can do anything to save some power, without too much of a sacrifice in capability.
My current setup:
HP Z6 G4 workstation with Xenon Gold 6142, 48GB DDR4 ECC RAM
GPU: GT710 (used so I don't have to run headless)
HBA: 9206-16E, with a Adaptec 82885T SAS expander in an external case & a seperate PSU.
NIC: 82599ES SFP+
Drives: 7xHDDs (8-16TB, combination of SATA & SAS), 3xNVMe (2x1TB in RAID1 to run Dockers, VMs etc from , 1x2TB as a general use cache)
OS: Unraid
My current usage for this is 170-250W normally (higher if it's under heavy usage, but normally it's under light load.
I already spin down my HDDs, which saves a bit.
I've considered replacing the machine with a lower power desktop machine, but my biggest issue is the PCI-E slots, as when I've looked before, to get the required slots I'd need to either stick with server, workstation, or high end desktop gear, which remains fairly expensive & doesn't give much of a power saving.
I'm open to any ideas, from changing a few settings I might have missed, through to a complete HW replacement, although if there are expenses incurred, I'd want a reasonable payback period (probably ~2 years max). Has anyone done similar & got any suggestions?
My current setup:
NIC: 82599ES SFP+
OS: Unraid
