- 18 May 2010
- London
Always latest stable version for me.
But whats the point if driver does not say new feature or performance upgrade?
Back in the day almost every driver would come with a few percent improvement in this game or that. Now you get fixes for things that do not apply to hardware configuration you have or games you are not playing.
I just update when needed. Like recently for example I got Dying Light The Beast. That said my driver was too old and to update. Just in time with the new DLSS4.5 update![]()
Up to date game support and bug fixes.
sorry im still on 566.36 every driver ive tried the entire year of 2025 has had some stupid bug and ive jut rolled backUp to date game support and bug fixes.
Everything i've read or seen about this new driver and DLSS 4.5 update has been pretty negative, it's all getting rather confusing for gamers.
Seems pretty straight forward to me.
Use DLSS 4 if you don't have a 4 or 5 series card.
For 4 and 5 owners, use L and ultra performance if you're targeting 4K, M and performance for everything else.
I stand to be corrected, of course.
Just an idea for people saying the new drivers cause problems - it might be an issue because of Windows and how it’s updated over time.
I bumped into some strange issues with drivers that were only resolved with a fresh windows install. No issues since then with Nvidia drivers.
Yep. I had this some months ago and I hadn't done a fresh windows install for a long time. Did a fresh install, everything worked perfectly fine after.
Historically i have always done a fresh install after i get a new GPU. Even if same manufacturer, but even more so if changing from AMD to Nvidia or vice versa.
I actually used to do a fresh install every 6-12 months when we were on HDD's and used to see a nice boost in snappiness of windows. These days it is 1-2 years for a fresh install.
I generally have no issues with GPU drivers, Likely because I reinstall Windows every 3 months and the entire install process with tweaks I now have down to maybe 2-3 hours.
Windows gets bogged down too easily and a fresh install really does make a difference especially if you use Winhance or MicroWin to debloat and desloppify a Windows 11 ISO.
Would you mind direct messaging me the process please as I’m due a fresh install soon.
Or as Nvidia likes doing every week after a new driver
HOTFIX![]()
Opeth will be on it as soon as it lands!![]()
