Squealing / noise from speakers
27 Jul 2010
Scotland
Hello - no doubt this has been covered a few times, but I just wanted to check before I buy a USB DAC. Plugging in a pair of active Edifier speakers into the motherboard results in quite a bit of unwanted noise. Sounds almost like GPU coil whine, it's a bit of a squeal.
The noise seems to fluctuate in line with CPU load as far as I can tell.
Would a cheap USB DAC solve this? Or is the interference just going to come down the USB port as well? Perhaps it depends on the DAC and any filtering it may do.
Try another source like a mp3 player, phone etc. If it doesn't making the noise then yes it's the PC, so a DAC should help.
If it still makes a noise from other sources then something is faulty inside the speakers, either the amplifier or ADC/DAC if it has DSP
Have you tried different speakers, or if possible using another output (for example the headphone jack on a case maybe?)
Tried plugging in a laptop and there was no noise, so it must be the cheap soundcard on the mini PC's motherboard
Almost any USB-C based mobile DAC should work, there's plenty for less than a tenner out there.
The biggest issue with PC onboard audio has always been the amount of noise that gets picked up from other components, I to this day wish there were motherboard options without built in audio for going on 15 years.
I have this issue with my PC - does your PC motherboard or speakers have optical input /output? I run my DAC off optical from the TV it's connected to, then to the PC via HDMI. This is how I used to use my Edifiers - they had optical input on my model. Doesn't matter how I connect my PC, if USB is involved I get EMI feedback noise. Using optical completely cured this. If you have optical on your Edifiers then maybe a USB to optical would be a simple solution to try.
