Images of items I have purchased (except trainers [no feet pics]) - Do NOT use imgur, postimage or imgbb!
Excellent choice, I've got the same ones, albeit the last model without that remote thingy. I do wish they had the option to change the volume between chat and game like my old Astros did though.
Yeah, I'm pretty impressed with them so far but only played a bit of Skyrim. Was pretty impressed how easy it was to get it working on both the PS5 and Switch 2. Literally plug and play.
I been wanting one of these Anker chargers for months
The Civic FN 2 3" Sports Cat and Manifold was fitted today
I didn't push the car as per conditions, but already the acceleration, the sound is leagues above what it was before! It gave me goosebumps. So far no management light, but it will be remapped again :cry:
Also check out the Ebay catalyst! it's under 2" just before the exit pipe. That's incredibly restrictive
On a higher output NA car, I would think 2.25" or 2.5" is probably all that is needed. 2" is on the small side (that's what she said)! Interesting you have gone 3". Are you FI?
FI?
On the Civic FN 2 Type R, 3" exhaust are the best you can get. In terms of rolling road, the piper comes out on top! So I went for the full 3" all the way to manifold
One guy had a japspeed 421 manifold Decat and 2.5 inch M2 cat back, replaced with a 3" Piper exhaust and made 17WHP over previous system!
Forgot to mention it's also a single pipe, unlike most are dual split :D
Bought this 600W servo motor a couple months ago but have only now used it to make a toolpost grinder for my lathe. Here I'm just finishing the grinding wheel guard necessary in case the wheel decides to self-destruct at 13K rpm.
only
Replaced my Elegoo Centauri Carbon with a Bambu P2S with the AMS 2 Pro, best purchase ever
Well, that sent me down a rabbit hole last night researching what changed since My Prusa i3 Mk2 that's been running since 2016! What stopped you staying with Elegoo and trying the just released Centauri Carbon 2? I don't do very much multi material, generally doing functional/engineering stuff, so the Elegoo stood out for having the multi material feature but without the big increase in price that the Bambu does. Saying that, the Bambu is a very attractive proposition.
Thankfully I can still tell myself I'm happy with my Mk2. Dialled in nicely and other than PETG being annoying - pritstick - it's dimensionally accurate enough for now! But it's only a matter of time I know, before I give in to temptation!
